Oooo sounds interesting, much like what I proposed after Monaco? http://somersf1.blogspot.co.uk/2012/06/ ... 2-now.htmlscarbs wrote:As long as theres the slot to the periphery of the floor then floor 'holes' are legal. Sauber and Ferrari still run them. I understand the new RBR slots are similar to the old ones with a large scoop joined to the fence inside the rear wheel.
Come on! Everybody knew how to make the slots legal.Matt Somers wrote:Oooo sounds interesting, much like what I proposed after Monaco? http://somersf1.blogspot.co.uk/2012/06/ ... 2-now.htmlscarbs wrote:As long as theres the slot to the periphery of the floor then floor 'holes' are legal. Sauber and Ferrari still run them. I understand the new RBR slots are similar to the old ones with a large scoop joined to the fence inside the rear wheel.
they could detach the floor from the aero strake (shown in orange). To make it a slot doesn't even mean being able to see the gap in the floor, it could be as fine as a hair.
Thanks Raymond that's precisely what I meant.raymondu999 wrote:Gilgen - I think Matt is suggesting a slit not to the side like Ferrari/Sauber, but to the back, along the vertical strake, as he says here:they could detach the floor from the aero strake (shown in orange). To make it a slot doesn't even mean being able to see the gap in the floor, it could be as fine as a hair.
Anyway, direct quotes to avoid confusion.Forza wrote:Today under FIAs supervision RB broke seals on bothe Vettel and Webber's gearboxes as they've changed the clutch basket on both units. Apparently they've changed that part in 4 of the last 5 events. Info is from twitter @cmckinleyF1 so I don't know if it's reliable.
Yes in some part i think you have right...siskue2005 wrote:I had a doubt when i saw last race, but now it clearly shows they have lowered their nose
The picture below confirms that RBR has lowered their nose
Is it coz they want a little bit more front downforce?
Interesting. What do you propose the air is choking against?siskue2005 wrote:I also think the pellican nose is there to reduce the air choking under the nose cone
Any shots of this new proposed solution for floor holes?Matt Somers wrote:Thanks Raymond that's precisely what I meant.raymondu999 wrote:Gilgen - I think Matt is suggesting a slit not to the side like Ferrari/Sauber, but to the back, along the vertical strake, as he says here:they could detach the floor from the aero strake (shown in orange). To make it a slot doesn't even mean being able to see the gap in the floor, it could be as fine as a hair.
Code: Select all
Red Bull will have to switch away from the safety of its old-spec alternators by the United States Grand Prix at the latest, AUTOSPORT has learned.
In the wake of the double alternator failure that Sebastian Vettel suffered at the Italian GP, Renault reverted its teams back to a 2011-specification to ensure there were no repeat problems.
However, with not enough of the old batch to last the entire season, Renault has continued work on a new version to make sure it has something ready for the final races.
Renault's head of track operations Remi Taffin told AUTOSPORT that the French car manufacturer was now happy that it has a version that should not suffer the same problems that have struck this year, and its teams would have to switch across imminently.
"The alternator has been changed and modified," he said. "We had a new version we tested in Singapore, and another one in Suzuka. We ran that one again in Korea - and will do so here in India as well.
"As well as that, we were running it on the dyno and that will become the specification that we will introduce this year when we need it. But we also have other specifications that are coming from R&D that are focused on 2013."
Taffin said that there is enough of the 2011 specification to last teams through the next two races, but that a switch over to the latest version would be needed for Austin.
"I think at the latest, and obviously it depends on the mileage we do, it should be the United States," he explained.
"Obviously it is not going to be for all teams, but we don't know for who yet."
Although Red Bull may feel reluctant to move away from the guaranteed reliability of the older version because of its championship situation, Taffin said the final decision about what the team does will be made by Renault alone.
When asked how Renault will decide when teams have to switch to the new version, Taffin said: "To be very honest it is a very difficult answer, because it is not any more just a technical issue. There are personal feelings about what should be run, and there are bad memories and things like that.
"So even if we have gone through all the validation process, when you discuss about introducing a new spec of alternator – people say, 'stop, should we not just keep with the old one'.
"The key point is where is the shift point from a 2011 unit with too much mileage on, to the new spec?
"But we will take the decision as always, because for any internals of the engine you cannot really leave that to the teams. It is not because they are not technically speaking OK to do that, but there is too much of an inside [emotional] feeling."
raymondu999 wrote:Interesting. What do you propose the air is choking against?siskue2005 wrote:I also think the pellican nose is there to reduce the air choking under the nose cone
Wasn't the concept of high noses introduced to have more air under the car?siskue2005 wrote:raymondu999 wrote:Interesting. What do you propose the air is choking against?siskue2005 wrote:I also think the pellican nose is there to reduce the air choking under the nose cone
here is what i propose, the higher the nose tip the air at that point has to change direction and has to slow down (red arrow) and may cause seperation at that point
where as the cleaner air can pass almost straight at will not decrease its speed (green arrow)
that maybe the reason for RBR decreasing its nose tip and also the pellican
