If it's not the Alternator then it's the Fuel..Same problem with Hamilton in Montmelo..
So Vettel will start from the back of the Grid , Interesting ..This Should help Fernando to take the Lead !
relaxed? he looks worried.Redragon wrote:The face of Vettel on the interview is quiet relaxed
Hamilton had enough fuel for his test, that's not the rule they will be punished for. You still have to make it back to the pits under your own power and failure to do so means disqualification from qualifying unless you are given dispensation by the FIA due to circumstances outside your control. The FIA didn't give that dispensation to Hamilton in Barcelona as it was a human mistake rather than a random act of bad luck.clipsy1H wrote:for what!! if he has enough fuel for tests why should get a penalty?stefan_ wrote:Vettel should start from the back of the grid because he didn't return to the pits / parc ferme after qualifying on its own power. He can have the right amount of fuel for the sample, but he should be penalised.
stefan_ wrote:Hamilton stopped after qualifying exactly for this reason - to have enough fuel for the required sample and he was thrown at the back of the grid. I am by no means a Hamilton fan, but let's see if there is a chance for consistency in applying penalties. Let's see if wonder boy gets to see the back of the cucumber.clipsy1H wrote:for what!! if he has enough fuel for tests why should get a penalty?stefan_ wrote:Vettel should start from the back of the grid because he didn't return to the pits / parc ferme after qualifying on its own power. He can have the right amount of fuel for the sample, but he should be penalised.
Yeah, very nervous laugh there when asked about it.FrukostScones wrote:relaxed? he looks worried.Redragon wrote:The face of Vettel on the interview is quiet relaxed
In fact its Grosjean/Lotus being investigated as Alonso left his garage first.banibhusan wrote:Alonso is also being investigated for unsafe release. But that'll most likely result in a fine for the team. So he should be safe.
That was Grosjean and Alonso. No further action.banibhusan wrote:Alonso is also being investigated for unsafe release. But that'll most likely result in a fine for the team. So he should be safe.
