It actually looks like it's rotating around the central axis, not only does it move backward and forward from the movement of the Pillars it would suggest the Wing moves left to right too.Joie de vivre wrote:nevermind, you were referring to the youtube video above
but if you look at .gif, nose-cone is flexing
I don't get why you've used your instead of you're?CottrellGP wrote:I dont get why your using images from last year??
what?Shakeman wrote:I don't get why you've used your instead of you're?CottrellGP wrote:I dont get why your using images from last year??
Do you not think that trying to correct another person's use of the english language, is a little childish?Shakeman wrote:I don't get why you've used your instead of you're?CottrellGP wrote:I dont get why your using images from last year??
in the gif the car is jumping over a kerb, every car will vibrate and jerk like the RBRMcMrocks wrote:in the GIF it seems that the nosecone makes the main part of the movement
You didn't answer my question?Shakeman wrote:I don't get why you've used your instead of you're?CottrellGP wrote:I dont get why your using images from last year??
Because the same is going on this year, thus the images are applicableCottrellGP wrote:You didn't answer my question?Shakeman wrote:I don't get why you've used your instead of you're?CottrellGP wrote:I dont get why your using images from last year??
It's an image processing method called posterization . Image color shades are reduced to a small number and close shades are combined into one. In this case it's done to underline the shadow/reflections movement on the nose cone surface as a result of deformation.siskue2005 wrote:in the gif the car is jumping over a kerb, every car will vibrate and jerk like the RBRMcMrocks wrote:in the GIF it seems that the nosecone makes the main part of the movement
moreover that video has wierd lightings , maybe they reduced the quality
