OK, let me start off by saying I am not trying to be a “d*ck”, I’m just having an interesting conversation with persons that seem to know something on the subject.
Jersey Tom wrote:Asphalt
I wasn’t sure what track surface you NASCAR guys do most of your running on. I though NASCAR ran on concrete and asphalt tracks but it must be hard with varying surfaces etc.
Jersey Tom wrote:Not sure I particularly like the term "mechanical keying."
OK, why??
If not described as mechanical keying or mechanical deformation, what would you call it?? As you rightly point out “
force generation is largely proportional to hysteretic loss”. So how does this “hysteretic loss” physically manifest itself in a tyre? Primarily as heat energy in the tyre carcass while secondary energy is lost to sound production is my understanding.
So in undergoing the processes of hysteretic loss, this imparts to the tyre a higher energy state which alters the viscosity of polymers forcing it to undergo transitions into or through its higher energy viscous or molten states. This in turn sees a more fluid polymer which can undergo higher degrees of plastic deformation at the tyre tread/track surface interface. This in turn increases the surface area due to deformation and provides for mechanical keying into the surface.
So perhaps it’s my (limited) understanding of what actually hysteretic loss is, how it effect the tyre and how it changes the interaction of the tyre with the track surface.
In a tyre, (my understanding) hysteretic loss occurs where there exists an energy difference between the energy input (seen as tyre deformation of the tread face and sidewall) versus energy output (energy used to return the tyre to its previous state) and the difference is accounted for as heat and sound energy which is required by the law of conservation of energy.
As previously discussed in the “Define tyre grip” thread, tyres are made of deformable polymers which are designed for optimum temperature and time ranges where their plastic deformation due to hysteretic loss energies can be used to provide mechanical keying into and adhesion onto the track surface.
So as the tyre rotates, the tyre tread face impacts the track surface and the entire tyre carcass and tread face is distorted by the vertical and horizontal forces acting on the tyre. This forms an interface between the track surface and the polymer compound of the tyre where the tread face deforms around the irregularities in the surface. These can effects are seen in irregularities from sub-millimeter to millimeter sizes. This is what I understand to be mechanic keying. The Racetech editorial by Pat SYMONDS (thanks again Dave) describes this as “asymmetric deformation”. Mechanical keying or asymmetric deformation due to high energy visco-elastic polymers within the tread face due hysteretic loss would seem to be one and the same.
Pat’s editorial also goes some way to helping describe my example of wet track lines and there being more grip off line due to increased mechanical keying by showing this can take place in the presence of a water film (wet track) where film thickness is not sufficient enough to prevent indention of the rubber into the track surface. It also helps to show one of the reasons (not the only reason) as to why wet weather tyres are typically made of much “softer” or more deformable polymers as they rely to a greater degree on the effect of mechanical keying into the surface for friction or "grip".
Jersey Tom wrote:Nor that I would necessarily say a large portion of force generation is from chemical bonding.
OK, so chemical bonding which I more simply described adhesion (which includes various forms of dispersive and chemical adhesion) is the interaction of the track surface and the tyre polymer. Again, the Racetech editorial described this more eloquently than me, providing that “molecular adhesion” was the Van Der Waals forces between the track surface and the tyre polymer and he equates this force as having an orders of magnitude of 10 to 100 times greater than that seen in more rigid non visco-elastic materials, like a cold tyre.
In addition to the Van Der Waals forces, a tyres dispersion adhesion is dependent on the effects of “wetting” between the viscous polymer and the track surface which is to various degrees further dependant on thermodynamic compatibility of two surfaces and surface “roughness” or texture. This interacts with the Van Der Waals force and can increase the adhesive strength.
The track surface consists of both high energy (the aggregate stones) and low energy (the bitumen matrix) surfaces, however the high energy aggregate forms the largest percentage of the surface for interaction. I have seen some modeling on this which was described as the wetting of non-ideal rough surfaces but it was years ago back at university so would struggle to talk intelligently on it without revision.
However again, the Racetech editorial seems to agree that “a large degree" of a tyres "grip" or CoF comes from mechanical keying described as asymmetric deformation and chemical bonding described as molecular adhesion. Pat SYMONDS specifically lists these two interactions under the sub heading of “
Mechanisms of tyre grip”.
Jersey Tom wrote:I would say that force generation is largely proportional to hysteretic loss.
There is a difference in defining the mechanisms of tyre CoF or “grip” as opposed to determining the proportionality of the effect on a tyre’s "grip" or CoF from the of various forces and energies enacted upon it.
So while force generation (seen as an increase or decrease in the tyres CoF) may be proportional to hysteretic loss, the energy involved influences the systems whereby the tyre enacts with its surroundings to generate a CoF in the first instance. Energy in, effect resulting from energy and energy out.
So while I don’t generally disagree that the hysteric losses proportionally effect force generation, I think your statement argues that hysteretic loss is
the system from which the tyre's CoF is derived rather than only an influence on the mechanisms which the tyre derives its CoF.
A tyre's CoF is a result of chemical and mechanical interactions on a micro and macro scale that are directly impacted by energies imparted to the tyre from hysteric losses. Hysteric loss, which is only an energy state descriptor, does not in and of itself provide any actual CoF to the tyre but merely affects those systems that do.
Jersey Tom wrote:But in that case, I can have a "harder" compound create more "grip" than a "softer" compound even if it has less indentation to the track.
How so?? The chemical bonding relies on surface area contact which increases with hysteretic loss due to heat energy input into the tyre allowing greater degrees of plastic deformation (flow) due to the polymers visco-elastic properties. A hard compound tyre will not indent to the same degree and so have a considerably lower lower surface area for bonding to take place and as such will generate a lower CoF or “grip”.
It is the same principle by which that the ubiquitous racer favorite, race tape / 100MPH tape / helicopter tape or duct tape works. Duct tape works better once you provide a force to press it in to or on to a surface. Use force to press it down and you increase the surface area of contact increasing the adhesive “chemical” bonding between the two surfaces. As said, these increase by orders of magnitude as surface area contact increases. Whereas, if you gently lay it on a hard surface without providing a force to it you can reasonably easily remove it as there is less adhesion.
So any hard compound tyre would only be “harder” when in it is in a low energy state prior to experiencing hysteretic loss through use which generates heat. If the tyre had a suitably high Glass Transition temperature then it would never undergo transition from a rigid solid to a molten or visco-elastic fluid and the required “asymmetric deformation" whioch increases surface area for chemical and mechanical bonding would not be able to take place and provide increases in the tyres CoF or grip.
Whereas if a softer compound tyres polymers, as an amorphous solid, have a sufficiently low Glass Transition temperature, whereby it starts as a generally rigid solid then transitions to a visco-elastic fluid once it has transited past the Glass Transition temp, it would be able to undergo greater degrees of plastic deformation and have a higher degree of indentation into the track surface due to the energy input from hysteretic loss in the tyre generating heat. This increases the surface area of the tyre/track surface interface increasing chemical bonding mechanisms of Van Der Walls and dispersion adhesion as well as the asymmetric deformation properties of the tyre.
Jersey Tom wrote:Well that's what we're talking about, no? A track that hasn't been run on? And I'd say it's more than just a dusty or dirty track. While that's part of it for the first few laps...
I was under the impression there had been more running at COFA than Brian’s indicated “ceremonial laps” performed so far, but if you know otherwise I will bow to your first hand knowledge as I am only hearing this 3rd and 4th hand.
Jersey Tom wrote:I'd say my experience is that a racetrack will continue to get faster after days of hard running. The surface really needs to be burnished in for the grip level to become consistent.
Again, I disagree with you but can understand what you’re saying and think what you are describing as "burnishing" is the "rubbering up" of the track over consecutive days of running. I think perhaps we are simply looking at different time horizons for the change. I absolutely agree a track gets faster as it rubbers up and as long it is doesn't rain of get oil, sand or other dumped all over it, tracks generally get faster over the course of an event.
However over a greater time horizon, a new track (less than 1 month old with little use and proper preparation) will have more grip than an older track (greater than 1 year, with regular use) due to aggregate wear. The quotes “delacf” provided seemed to generally indicate differences of tracks over a wider time horizon due to wear while also showing that a tracks characteristics change as it “rubbers up”.
Jersey Tom wrote:In any event, this...
aussiegman wrote:Several readings were taken from the machine, in order to ensure an accurate representation. Using these readings a virtual representation of the track from the tyre’s point of view can be created on computer.
Together with some asphalt samples from the new venue, this allowed Pirelli to calculate the likely wear rate and the effect of the asphalt and ambient temperatures on the tyres at different points on the circuit."
... my gut feeling is that's an awfully big stretch from their marketing department. Or I'm sure they can come up with a "calculation" but any degree of accuracy is a big mountain to climb.
Pirelli have photos of their staff at the track with measuring equipment and I have seen tyre manufacturers doing exactly the same thing at Australia’s Phillip Island before motoGP races.
Again Pat SYMONDS describes that Bridgestone “measures this (micro and macro roughness) using an optical device that determines the height of surface irregularities in representative parts of the track.”
So while they would likely be averaging the results, they would be measuring the sizes and “roughness” of the aggregate chips in the tarmac to properly assess a tracks ability to provide “grip”.
Jersey Tom wrote:In any event, my assessment is this: Brand new track is slow and will pick up speed as it's initially worn in and stabilizes. Until then it's very difficult to assess setup changes or performance relative to the field because any time you make an outing... even if you don't change the car at all... you'll go faster. From a tire company perspective repaves can be hell, as the speeds and loads wind up being high and the tires don't wear much or at all. As a result you end up with quite high tread temperatures and durability concerns.
Beyond that, it's been a while since I've read his book(s) but many of Paul's assertions with tires I've found to be questionable at best and incorrect at worst. As such, I'm wary of just about all of it.
BTW, whose “Paul”?? Anyway, for a brand new, not prep’d, not washed, not dressed track maybe sure. I’ll concede that it might be slow and get faster over the weekend. However, compare the same track as with a sub 1 month aged surface and the same surface after use of say greater than 1 year or even 2 to 3 years constant use and I would expect the new track however prep’d to record faster times as was borne out in CART’s experience with ’96 the Laguna Seca resurface. I did a little more searching on this and the CART cars were apparently 1 to 3 seconds slower a six months later when they returned.
I would also agree that more aggressive surface could very well cause durability and heat issues as this is exactly what happens when you run on the high grip surfaces at Paul Ricard, it tears and overheats the tyres very quickly due to masses of inherent “grip”. But that’s a different discussion.
