Mercedes AMG F1 W03
elf341
elf341
Re: Mercedes AMG F1 W03
Are they allowed to run sensor arrays during practice sessions?
banibhusan
Yes. Why wouldn't they be??
scarbs
scarbs
393
They are allowed to run more sensors on a Friday, the car was photo'd with the sidepods off and bundles or clear plastic tubes were shown, clearly they are going to be doing some comparative runs for aero data...
http://www.formula1.com/wi/0x0/sutton/2 ... usa672.jpg
SchuMassa
SchuMassa
21
US GP: Nico Rosberg to run old Mercedes exhaust in practice
http://www.autosport.com/news/report.php/id/104269
Okay that is just really, really embarassing
Forza
238
US GP - FP1: Mercedes revised DRS actuator via @Mario Keszeli. They are also testing DRD
scarbs wrote:They are allowed to run more sensors on a Friday, the car was photo'd with the sidepods off and bundles or clear plastic tubes were shown, clearly they are going to be doing some comparative runs for aero data...
Isn't that a Lotus?
Forza
238
US GP - FP1
Close-up view of DRS actuator
techF1LES
176
Isn't that a Lotus?
No, 100% Mercedes.
elf341
elf341
The rear wing endplate actuator was another area that Mercedes went at alone against pit-lane concensus. What could be the reason for changing now?
aleks_ader
90
elf341 wrote:The rear wing endplate actuator was another area that Mercedes went at alone against pit-lane concensus. What could be the reason for changing now?
I asume weight (CofG)...
scarbs
scarbs
393
Simplicity, their original hydraulic\cable operated system was straight forward until Schumacher's Canadian failure, the gearbox mounted actuator had to be revised to positively close the flap. Having a simple rear wing mounted actuator will have less parts, less to go wrong and less weight, albeit the small amount of remaining weight will be carried higher.
Forza
238
Few more close-up photos from US GP - FP1 & FP2
Vasconia
wesley123 wrote:Okay that is just really, really embarassing
Actually, the embarrasing fact is that the car seems to be much faster with the old exhaust than the new one, look at the enormous gap between Michael and Nico, Its funny and sad at the same time. :mrgreen:
marcush.
marcush.
159
two failures in important situations this year..but why change so late in the season, lack of development capacity?
Mercedes has turned around on their caliper position again from horizontal low to conventional quasi vertical mount -something they did already after 2009 ...
