Autoclave-less carbon fiber?
g-force_addict
g-force_addict
Maybe FIA should give some rewards for teams that use out of autoclave carbon fiber parts?
In order to allow opportunity for smaller teams and to smooth carbon fiber transition to every day cars.
Some say autoclave only adds a minimal strength increase at a huge cost and delay:
http://www.gmtcomposites.com/why/autoclave
http://www.compositesworld.com/articles ... revolution
Jersey Tom
Jersey Tom
Re: Autoclave-less carbon fiber?
There is no reason for carbon in "every day" cars IMO. Only reason it's used is for marketing. Composites manufacture is already quite well established outside of racing - it's not like F1 teams are "paving the way" or whatever.
Lycoming
Lycoming
106
all of them already own an autoclave anyway....
marcush.
marcush.
159
AoA is not really a ways towards automotive usage of carbonfibres -the scrimp process (infusion) or matrix film layup is not really leading itself to short cycling times in production.
A resin sysem with cycle times of hours or something is never going to be feasible for mass production-so what.
Holm86
247
Jersey Tom wrote:There is no reason for carbon in "every day" cars IMO. Only reason it's used is for marketing. Composites manufacture is already quite well established outside of racing - it's not like F1 teams are "paving the way" or whatever.
Of course theres a reason for carbon i every day cars. If carbon at some point could be cheaper or at same price level as steel then every day cars with full carbon chassis and bodyparts would be alot lighter than current cars. Which ups both performance and fuel mileage.
strad
117
:roll: I've mentioned many times that for most parts, they no longer use the Autoclave. :roll:
You can lay it up much like fiberglass.
Sir Stirling Moss
piast9
piast9
Holm86 wrote:
Jersey Tom wrote:Of course theres a reason for carbon i every day cars. If carbon at some point could be cheaper or at same price level as steel then every day cars with full carbon chassis and bodyparts would be alot lighter than current cars.
But it wouldn't. It will always be more expensive than steel.
On the weight side - I am not so sure about its significant impact on the weight of the road car. Look at the weight of the supercars. For example carbon-fibre Mclaren MP4-12c weights 1300 kg while Noble M600, which is partially CF partially steel weights even a bit less. Additionally - they weigh only 100-200 kg less than the full metal supercars from 80's.
Greg Locock
Greg Locock
235
What all-metal supercars were they? Mostly the supercars in the 80s were glassfibre over welded steel underpinnings.
Anyway that isn't a particulalry goood comparison as a modern Countach derivative includes a lot more stuff, has much bigger wheels, and passes far more stringent tests than an 80s one.
marcush.
marcush.
159
one important point is:
for weight savings composite ,not carbonfibre is what is driving the weight down.
In fact a glassfibre skin can be made lighter than carbonfibre ,which is very hard to get a closed surface with no telegraphing ..
so a nomex paper core with glass skins is what you need to make a ultralight panel.
I´d guess most of the cf use in car production is just a matter of being fancy.It´s a bit like the EV vehicle hype.
aussiegman
aussiegman
105
For a $10,000 econobox if you could make it from carbon for that price there would be efficiency advantages, however the only carbon you see on the average cheap Kia/Hyundai/Chery "every day" econobox car is 3M vinyl or other no use stickers. Occasionally there may be some carbon trim but yeah its of no use. However, when you say every day I would include moderate to high volume production cars that car be driven on the road every day.
In these cases, carbon vs steel, aluminum etc has considerable weight, tensile and compressive strength qualities, higher fatigue resistance as well as the ability to follow / be molded into complex curvatures all of which can increase survivability and increase power-to-weight- stiffness-to-weight which in turn has a significant effect on fuel economy (CO2 emissions is all encompassing in Europe and Asia) as well as performance.
As such, there are a myriad of reasons to use carbon fibre or other composites over steel because of the above.
The main reason it is not mainstream is simply cost of material and production difficulties. So IMHO there is every reason aside from marketing to use it in "every day" production cars based on its properties, however until the various costs come down it will not be a mainstream material.
The only other downside for production cars is the ability of CFRP, GRP etc to be recycled after lifecycle.
Jersey Tom wrote:Only reason it's used is for marketing.
That's a very cynical and myopic view of the situation I think.
If it gave no benefit other than marketing then its usefulness would be limited and we wouldn't be seeing the recent expansion in it use. Companies like Audi, Porsche, Mercedes and BMW (see a pattern there, cost and Euro based design where efficiency is the primary driver) now have used composites in their production cars. However as before, cost it the main barrier to further usage.
As an example, are you certain that the carbon composite roof used on the BMW M3 was done only for "marketing" and did not reduce the vehicles centre of gravity by removing 7kgs of weight from the highest point of the vehicle? Was it only "cosmetic" then?? Same opinion for the previous generation CSL?? The M3 is an "every day" car as its high volume and based on a four door saloon and in the numbers they sell they are not a limited production run or exclusive item.
However as an example of manufacturers investing in carbon manufacturing technologies for future prodcution, the Audi Group established the "Automobili Lamborghini Advanced Composite Structures Laboratory" (ACSL) in the USA on the University of Washington campus in Seattle where they partnered with Boeing and moved the Lamborghini Gallardo LP570-4 Superleggera to a new carbon chassis production methodology pioneered by Boeing for the 787 Dreamliner project. This was not a marketing ploy and had everything to do with gaining a performance benefit as well as a better understanding of the technologies for mass production possibilities. Scalability and cost are the drivers for carbon.
It is interesting that the use of the Boeing techniques saw improved construction remove 40+kgs from the car (still just marketing??) so the LP570-4 Superleggera had a dry weight of 1340 kilograms (2954 lb) which would be impossible with steel or aluminum while retaining the stiffness required while the carbon construction provides for better power-to-weight and stiffness-to-weight ratios by reducing total mass which also is important for fuel economy and CO2 emissions in this era. This is the benefit of carbon.
Jersey Tom wrote:Composites manufacture is already quite well established outside of racing - it's not like F1 teams are "paving the way" or whatever.
Yes, production techniques and methodologies are generally well understood however new ones do filter filter down from aerospace and racing and provide more cost effective scalability for general production runs.
F1 in this area are more adopters than innovators due to cost of R&D, however they have certainly helped drive the technology faster than if they weren't involved.
marcush. wrote:one important point is:
Telegraphing or print through is fairly easy to control if you use the right weight cloth and interfacing method.
So you may be able to make a lighter glass panel but it will not have similar or greater stiffness, tensile or compressive strength than a similarly weighted carbon panel. Carbon is simply a stronger fibre reinforcement than e-glass or s-glass. That's not to say that glass panels and layups are no good, its just carbon is stiffer and stronger for a given weight however these properties may not be required for certain applications.
Glass reinforcements, both s-glass and e-glass, are relatively inexpensive and have moderate tensile and compressive strengths while showing average stiffness when compared to carbon or aramid cloths. Glass variants show good fatigue resistance however and are therefore very tolerant of cyclic loadings.
Carbon Fibre has considerably lower weight, higher stiffness and tensile strength than the either of the glass fibres. Its downsides are cost and the more involved techniques required to properly achieve matrix suitability and application (such as resin penetration or wetting out).
Kevlar as an aramid fibre, has the lowest density of the most uses reinforcements high tensile strength and superior toughness (abrasion, cut and tear resistance). It toughness make it harder to work with and when used alone exhibits poor compressive properties. This is predominately why Kevlar is used in hybrid fabrics and layups with the various glass fibre or carbon to increase stiffness and compressive strength over Kevlar alone.
marcush. wrote:so a nomex paper core with glass skins is what you need to make a ultralight panel.
It may be lighter but would it have the same or greater strength, stiffness or impact resistance as a carbon, kevlar or hybrid panel??
In reality for production cars, if you want light non-weight baring panels simple thermoformed plastic is the easiest solution. It is light, can be pigmented, has great deformability resistance and is cheap and recyclable.
marcush. wrote:I´d guess most of the cf use in car production is just a matter of being fancy.It´s a bit like the EV vehicle hype.
I'd disagree with this. Glass variants are less stiff, have less compressive and tensile strength and therefore you need to make a thicker heavier panel to take the same loadings. Sure in some application you could substitute glass for carbon on a cost basis but I would not think a replacement based purely on weight or other properties would be made.
From my personal experience, the biggest difference in these fabrics is the techniques used for making parts of parts.
I use carbon (particularly spread tow fabrics), Kevlar and hybrid fabrics in making various parts for my car and sailing equipment. So far I’ve managed a few splitters (with soric core mat, balsa wood and nomex cores), guards, bonnets (Hood), flat panels (Kevlar cored anti intrusion side protection panel to attach to the roll cage, floor panels and dash panels etc), as well as a few tubes (using sleeves and wound tapes on styrene and water soluble cores).
I ever tried a 9’6” carbon / Kevlar sail board using a foam blank!!
However, I can only use wet layups with vacuum bagging where possible due to having no access to or the cash for a $100,000+ autoclave. The biggest difference in wet vs. dry is component weigh due to excess resin and the associated strength loss you get due to the larger resin pockets in the layups. I tried using a pre-preg fabric and vacuum bagging it however the warm weather and short shelf life makes it simply too costly.
Print through of the bleed ply and/of the fabric weave can be an issue if not bagged correctly with pin holes or poor surface finish the result. Incorrect wetting out of the fabric or core with the resin also can be an issue when your DIY’ing.
Lycoming
Lycoming
106
A lamborghini and bmw m3 aren't exactly "every day" cars. If we're talking about things like the prius, the cruze, the corolla, composites are too costly to be used in any significant quantity. You will not drop 40 kg from cars like that because the cost of the composites required to do so would be way too expensive; there are other ways to drop weight, Subaru took 100 kg off the Impreza when they did a big redesign last year.
In cars like this, yea, carbon fiber trim is basically marketing. That's why they sell fake carbon fiber patterns that you stick over top of your regular trim.
In general carbon fiber is not a great material; its expensive as hell and very brittle. It's about using different materials for different jobs. You use carbon in a lamborghini because the issues of cost and difficulty in manufacturing are more tolerable in that context; likewise you use aluminum/steel/whatever alloy in a typical road car because you need to balance cost and ease of manufacturing. When you need to make hundreds of thousands of vehicles in a relatively short timeframe at a competitive price, carbon is a god awful material to use. Considering this, carbon's not the most suitable material for the job, so why use it in meaningful quantities, aside from maybe a simple decorative panel hero or there? Thats why there's no reason to use it in "every day" cars, and why its just marketing hype.
aussiegman
aussiegman
105
Lycoming wrote:A lamborghini and bmw m3 aren't exactly "every day" cars.
Agree the Lambo is no every day car, but is was an example of the investment Audi has made for the benefit of its everyday car range.
As for the M3 I'd say it was an every day car, if at the higher end of the spectrum. It has 4 /5 seats, 2 or 4 doors, a decent boot and is not hideously expensive (at least anywhere outside Australia where we get slaughtered by import taxes and the tyranny of distance).
Lycoming wrote:If we're talking about things like the prius, the cruze, the corolla, composites are too costly to be used in any significant quantity. You will not drop 40 kg from cars like that because the cost of the composites required to do so would be way too expensive; there are other ways to drop weight, Subaru took 100 kg off the Impreza when they did a big redesign last year.
Agree on the cost and manufacturing issues with carbon, however it has substantial benefits where the cost is justified or can be absorbed. The Impreza re-design dropped weight by using better alloys and improved chassis design allowing for better inherent chassis stiffness and bracing designs. Thats where the 100kgs came from. If they could do a 100% carbon chassis they would have dropped 3 or 4 times that amount, however increased cost by 10+ times and production times by who knows what.
Lycoming wrote:In cars like this, yea, carbon fiber trim is basically marketing. That's why they sell fake carbon fiber patterns that you stick over top of your regular trim.
And are crap!! :lol:
Lycoming wrote:In general carbon fiber is not a great material; its expensive as hell and very brittle. It's about using different materials for different jobs. You use carbon in a lamborghini because the issues of cost and difficulty in manufacturing are more tolerable in that context;
What you are talking about is economies of scale and profitability, not the materials ability to add a benefit to the car aside from marketing.
Lycoming wrote:likewise you use aluminum/steel/whatever alloy in a typical road car because you need to balance cost and ease of manufacturing.
As well as longevity. Aluminum wasn't used in great quantities previously for some of the reasons carbon isn't used now. Material cost, production cost, scalability issues etc. As carbon matures answers might be found for these problems. IN aluminum's case it was different alloys with increased fatigue resistance and easier bauxite processing reducing the price/kg or raw aluminum stock. For carbon, lower base material cost and easier production methods would help substantially.
Lycoming wrote:When you need to make hundreds of thousands of vehicles in a relatively short timeframe at a competitive price, carbon is a god awful material to use. Considering this, carbon's not the most suitable material for the job, so why use it in meaningful quantities, aside from maybe a simple decorative panel hero or there? Thats why there's no reason to use it in "every day" cars, and why its just marketing hype.
Yep, 100% agree that currently for modern disposable item quick production times, carbon currently is less than ideal, however that does not mean that it has no place other than as a marketing tool. If you could produce a cost effective, lighter, stronger roof panel/bonnet/boot etc that reduced weight and allowed greater efficiency then a cost per unit increase may be acceptable for the benefit gained. That's how BMW and others look at it.
From a materials view point the application of these technologies (setting aside carbon trims and stickers) is being used and looked at more closely for its weight, stiffness and longevity advantages by the manufacturers. Solve the cost, production and long term UV stability issues and it could be more mainstream. They did it for aluminum which was expensive, brittle, hard to machine and was susceptible to fatigue cracking. This was one of the predominate reasons aluminum fell out of favor or never gained favor as it had an "image" problem with the public and engineers after the hihgly publicised crashes of a number of de Havilland DH 106 Comets which was traced back to stress cracks in the aluminum skin.
Better alloys and manufacturing means aluminum is now in favor and its use is increasing for the benefits or weight. And that's not a marketing thing and is where carbon could be to some extent in the future.
IF (and it is a big IF) you could get to a level with decent economies of scale using carbon or other fibre reinforcements then the efficiency gains would be substantial.
You could easily remove 40+kgs from a Prius (though how and why you would bother trying to justify it on a car that costs twice as much and has a larger global carbon foot print than a VW Golf is beyond me!!) however the largest weight component in that car is the batteries.
Same drive components in a carbon body would weight less, go further and reduce overall emissions. However as you rightly pointed out, cost is the issue.
Economies doesn't make carbon a marketing tool, it makes it too expensive for mainstream economies. However where the cost can be absorbed then is has advantages.
strad
117
Cynical...but true. :wink:
Sir Stirling Moss
jimbojones1000
jimbojones1000
I read an article a while back with someone from Mclaren road cars talking about their consultant work with toyota i think, he said that the material cost of CF is the same as aluminium its that the path the material takes to the end user that is so convoluted that the price is ramped up by everyone getting their profit, and that large car companies can and will use CF in small cars once they have the right construction techniques as their buying power/manufacturing will bring it down to the cost of current materials.
Greg Locock
Greg Locock
235
jimbojones1000 wrote:I read an article a while back with someone from Mclaren road cars talking about their consultant work with toyota i think, he said that the material cost of CF is the same as aluminium its that the path the material takes to the end user that is so convoluted that the price is ramped up by everyone getting their profit, and that large car companies can and will use CF in small cars once they have the right construction techniques as their buying power/manufacturing will bring it down to the cost of current materials.
Well, it'd be interesting to read that article, I think Aluminium was $4000 per tonne last time I checked (a long time ago). http://gizmodo.com/5843276/why-is-carbo ... -expensive
