Khamsin Virtual Racecar challenge 2013 (CFD model racing)
N12ck
Re: F1 model CFD Challenge (Khamsin Virtual Racecar challeng
Hi,
Results will be posted tonight after the actual F1 race, and I will email PDF files to you all,
Thanks
Nick
Budding F1 Engineer
machin
162
Looking forward to seeing how the different designs compare!!!
N12ck
machin wrote:Looking forward to seeing how the different designs compare!!!
updating the website with results, images of cars will be put up tomorrow, and PDF's will be sent tomorrow :)
Budding F1 Engineer
N12ck
results up, Variante was the fastest design :)
Budding F1 Engineer
machin
162
I hope you don't mind Nick, but this is a good image!
KVRC Website Front page wrote:
Markus
Markus
As expected I was last but without a diffuser and a front wing that you need to use a magnifying lens to see I don´t think it´s too bad.
machin
162
Looks like Variante's car (pictured above) is a nice clean design which probably goes a long way to explaining why it won...
Its interesting that most designs had a pretty good downforce distribution.... around 60% rear on most designs.... so most people need to get a tiny bit more front end to balance their designs... except Mareli who actually achieved the second highest downforce overall, but a whopping 82% of that downforce coming from the front end....
Looking forward to seeing pictures of the different cars!
wigglez28
wigglez28
Sorry to sound dumb but what do the Cd.A and Ci.A things actually mean?
N12ck
There were some cars which were completely illegal, which teams will soon know what was illegal
Cd.A is the Coefficient of Drag x Area
Cl.A is the Coefficient of Lift X Area (We are treating downforce as positive)
Budding F1 Engineer
astracrazy
astracrazy
31
are you not going to do it as listed in the cfd example? drag in newtons and downforce in newtons?
i don't quiet get it :|
edit: now i do cheers
machin
162
wigglez28 wrote:Sorry to sound dumb but what do the Cd.A and Ci.A things actually mean?
Cd.A is the coefficient of drag multiplied by the car's frontal area... higher means more drag (bad)
Cl.A is the coefficient of lift(or downforce) multiplied by the car's frontal area. Higher is better.
The C.O.P is the centre of pressure and represents the distance from the car's front axle at which the downforce would have to act if it were treated as a point load. You want it to be around 1.9m so it matches the mass distribution and therefore gives a good balance for optimum cornering performance.
EDIt; beat me to it Nick!
stez90
stez90
Not bad.. 2nd place at Monaco with Cl that looks like from Monza :D
machin
162
Interesting comparison between Cottrell and RicMe; Cottrell had more drag and less downforce overall, but a better balance of the downforce it did have, and hence a slightly better lap time... but it was close!
etsmc
etsmc
Happy with my 5th place. from the results it looks like i need more downforce overall but more towards the front..
RicME85
52
Interesting results, will be very curious to see the files that get sent out.
What I find most interesting is that mine and Dan's cars, both of which probably very similar to Formula Sketch cars were trumped by someone starting with a blank slate and creating something that looked very basic in comparison.
