heho07 wrote:How DRS can stall diffuser?
Ok, maybe not the best choice of words, Gary Anderson explains it best.
"In qualifying, the DRS overtaking aid can be used all the time. A driver comes off a corner and opens the DRS as soon as possible, reducing the drag and the wing wake, which gives extra straight-line speed.
As the car goes faster, the rear gets closer to the ground and that 'stalls' the diffuser, which is the underfloor which curves upwards at the back of the car. 'Stalling' means the airflow is not attached to it any more, and that reduces the downforce it produces.
When the driver brakes for the next corner, the car changes attitude - the rear comes up.
I am 99.99% sure that at that time, on the Ferrari, the diffuser does not re-attach immediately.
Because of that, the airflow at the back of the car is different, so the rear wing does not re-attach either.
So on initial corner entry, 18 or 20 times a lap in qualifying or whatever, the rear of the car has less downforce and therefore is unstable for a given amount of time until the diffuser and rear wing re-attach.
This rear instability on corner entry is what the Ferrari drivers are complaining about"
Do you feel you can beat the Red Bulls, either to pole position or the race itself?
Fernando Alonso: "I prefer to beat them on Sunday."
