Thanks for posting! Very cool.DAMNINice wrote:I think they used a trick Scarbs wrote about earlier...
They used the panel to create a higher Nose:
Very clever!
3.7.9 With the exception of an optional, single piece, non-structural fairing of prescribed laminate (whose precise lay-up may be found in the Appendix to the regulations) which may not be more than 625mm above the reference plane at any point, no bodywork situated more than 1950mm forward of rear face of the cockpit entry template may be more than 550mm above the reference plane.Raptor22 wrote:the tip can still droop.
and why can't the front wing be mounted to the modesty panel?
It could be done without mounting to the fairing. I don't have the resources to make a pretty drawing though. Sorry!.poz wrote:3.7.9 With the exception of an optional, single piece, non-structural fairing of prescribed laminate (whose precise lay-up may be found in the Appendix to the regulations) which may not be more than 625mm above the reference plane at any point, no bodywork situated more than 1950mm forward of rear face of the cockpit entry template may be more than 550mm above the reference plane.Raptor22 wrote:the tip can still droop.
Non-structural fairing laminate specification
General laminate: 1 ply woven 200g carbon (0.2mm) / 3mm Nomex core / 1 ply woven 200g carbon.
Edge reinforcement: The edge of the laminate may be reinforced with a further 2 plys of woven 200g carbon (1 either side of the core) which may extend no further than 20mm in from the perimeter of the fairing.
you got it EXACTLY right! a few pages back i highlighted the yellow area in which the structural part of the nose can not enter...extrater wrote:It is very hard to match these cars properly. I suppose yellow line shows where is a bottom of modesty panel (maybe should be one or two pixels higher).
Something like this ?hairy_scotsman wrote: It could be done without mounting to the fairing. I don't have the resources to make a pretty drawing though. Sorry!
Not that again! The tip of the nose cannot be at that height!.poz wrote:Something like this ?hairy_scotsman wrote: It could be done without mounting to the fairing. I don't have the resources to make a pretty drawing though. Sorry!
I repeat. The TIP of the nose has to be at a maximum specified height. Any fairing cannot be above that height. The reason for the height restriction was to prevent a high nose overriding the cockpit sides of another car, in event of a t-bone..poz wrote:An idea:
The F138 has those big vertical fin in place of small pylons... we don't know which part of them is structural
is something like this legal ? (sorry for poor drawing skill)
Since 2009 Red Bull has used a fairing in different formats to cover the half shaft, the track rod (for adjusting toe angle) and half of the lower rear wishbone. The reason for this is that the rotation of the half shaft produces downforce because of the Magnus Effect, which is good. The problem is that when you introduce the exhaust plume into the equation, this effect becomes more unstable as exhaust flow is given out by the engine only on every exhaust stroke.
In addition, covering them will provide a clearer path for the airflow at the rear of the car allowing the diffuser to produce more downforce.
This year Ferrari, McLaren, Force India, Sauber, Lotus and Mercedes (up to the day of posting this) have followed Red Bull's path of using the half shaft shroud as it is more aerodynamic than having them separate.
http://technicalf1explained.blogspot.co ... iring.html
If the tip of the nose is composed by the vanity panel (and the vanity panel only), it would be against the intent of the rules but within it as the only defined max height of the panel is 625mm above reference plane. The FIA would surely clarify the regulation though.gilgen wrote:I repeat. The TIP of the nose has to be at a maximum specified height. Any fairing cannot be above that height. The reason for the height restriction was to prevent a high nose overriding the cockpit sides of another car, in event of a t-bone.
The yellow part is not a nose tip, it's "an optional, single piece, non-structural fairing of prescribed laminate"gilgen wrote: I repeat. The TIP of the nose has to be at a maximum specified height. Any fairing cannot be above that height. The reason for the height restriction was to prevent a high nose overriding the cockpit sides of another car, in event of a t-bone.
I think that is a distinct possibility (although i do not have the rules in front of me). The tip of the nose is the tan structure and could be at max height. It is the modesty panel that extends higher and further ahead and by definition the modesty panel will ALWAYS be above the max height for the nose because it is meant to be above the step in the nose.gilgen wrote:I repeat. The TIP of the nose has to be at a maximum specified height. Any fairing cannot be above that height. The reason for the height restriction was to prevent a high nose overriding the cockpit sides of another car, in event of a t-bone..poz wrote:An idea:
