ginsu wrote:
If the rear is anything like the front (Bahrain 06), then it would be very easy to route air back out towards the inside of the wheel.
The rear brake duct is different from the front, I tried to make my model conceptually similar to it (at least, to what I believe it looks like).
That’s the 248F1 :
[IMG:150:128]http://img437.imageshack.us/img437/3678 ... lr7.th.jpg[/img]
Unfortunately in this pic just like in all I found the rear side isn’t visible so I’m not sure it’s like the previous years cars, I assume it is (this is the F2003GA but also on F2004 and 2005 was similar) :
[IMG:150:128]http://img441.imageshack.us/img441/6785 ... ek8.th.jpg[/img]
If the assumption is correct and the 248F1 is similar to previous years cars then the air exiting from the outlet on the inside is most likely taken from the duct covering the caliper (and the pads), it’s obvious that it includes consequently all the carbon dust generated by disc and pads wear and would explain why the endplate is covered with dust at the end of race.
The doubt is about the air exiting from other part of the disc circumference, the non covered ones. This air is hot but, relatively, clean (meaning it doesn’t include much carbon dust) so it doesn’t leave noticeable traces to identify its path. Most likely it goes out thru the wheel spokes, but I can’t tell how big the clearance between the “donut” and the inner side of the rim is (the only thing I can tell is that the transversal section of the “donut” on the 248F1 appears to be slightly less “rounded“ than in the previous years). It’s also possible that part of cooling air goes out from the other gaps, for example the upper part of the rim on the inside, where the upper wishbone passes, isn’t completely closed, maybe a fraction of air leaks out from there too. If that’s the case or not it depends by the clearance between the donut and the rim inside face, the size of the other gaps etc etc.
manchild wrote:
I'm sure that rim is "pressurized" a bit since inlet duct works as ram-air system and hot air can't exit as fast as cold air enters and if so than hot air fills whole space reaching fairing wall and partly exiting outside. It could be said that aperture in fairing has some sort of BOV function - when outlet duct can't swallow as much as inlet duct bites than aperture in fairing prevents overheating by letting some of hot air out.
First question.
Imagine you are the passenger in a car going at 200 km/h and you have a toy balloon that you want to inflate. You open the window and put the balloon outside, keeping the open end straight against the incoming flow. How much time does it take for the balloon to be inflated ?
Second question.
How much “hot” do you believe the cooling air becomes after passing thru the disc ? 50°, 100°, 300° ? We know that the disc reaches often temp in the order of 800-900 °C, but what about the cooling air ?
