No, that is why there is a brake bias adjuster. I am wondering if the brake line failed, or if something in the bias adjuster did?Ferraripilot wrote:Hydraulic issue for sure. Interesting how it only affected the rear though. Are F1 braking hydraulic systems independent front and rear?
The car, has changes in the rear suspension, i think that the upper arm is mount higher to the chassis. This leads to changes in the hydraulic connections to the brakes. And there is the problem. The team has decide to change all the system, against future problems.Ferraripilot wrote:Hydraulic issue for sure. Interesting how it only affected the rear though. Are F1 braking hydraulic systems independent front and rear?
Do the regulations allow the brake hydraulic system to be tied to a hydraulic suspension system? I think no, and I remember having these talks last year, but forgot the outcome.
I don't see what a brake bias adjuster has to do with only one braking hydraulic system. A brake bias adjuster can easily act on two master cylinders (one for the front, one for the rear).Ferraripilot wrote:dren wrote:
That's what I thought which is why only the rears failing doesn't make sense to me.
Bias adjuster failure may fit?
Lurk wrote:I don't see what a brake bias adjuster has to do with only one braking hydraulic system. A brake bias adjuster can easily act on two master cylinders (one for the front, one for the rear).Ferraripilot wrote:dren wrote:
And of course front/rear hydraulic circuits are independent in a formula on car. Why there would be 2 brake fluid reservoirs mounted in front of the chassis otherwise?
Plus it would be crazy to race a car with a single brake circuit!
How about this then:richard_leeds wrote:
Focus on the car
