Ferrari F138
PistoneRovente
PistoneRovente
Re: Ferrari F138
Most definitely a hole, as confirmed by this article on Omnicorse.
http://www.omnicorse.it/magazine/24852/ ... e-si-vede-
And if you still have any doubt, check this out
http://i3.photobucket.com/albums/y62/So ... 763cf7.jpg
Lurk
Re: Ferrari F138
jaba.hut wrote:Didn't see this coming:
http://www.bbc.co.uk/sport/0/formula1/21417831
Gary Anderson says F138 wit McL probably fastest car in Jerez.
That's nice to see he didn't take account of the tyres or the track, at all. He's paid to write something and he just wrote another junk article...
Maxion
Maxion
Re: Ferrari F138
Indeed. Already from a normal F1 weekend it's pretty apparent that the track gets faster as the miles go down on the track.
Spankyham
Re: Ferrari F138
Let's assume Ferrari have decided to push the limits in terms of rules. And lets say, the opening is directing air, under the driver into so region of benefit. You would at least need to put up some sort of pretense that there was a significant need for driver cooling. It was very early on that Felipe complained about the heat.
Blind Freddy can see that the opening is way overkill for that stated task, but, in the same vein as they didn't stop engine overrun (despite the fact that it was so obvious that teams were going to extremes beyond what was necessary) perhaps Ferrari is hoping their "hole-in-the-nose-gate" opening will get the same treatment by CW et al.
"He was the fastest driver I ever saw - faster even than Fangio"
_______________________________- Mike Hawthorn on Alberto Ascari
aral
aral
26
Re: Ferrari F138
Is it or is it not a hole for driver cooling? That is the question...
It should be noted that days 3 and 4, when the 'driver cooling hole' appeared, temperatures were down at around 3 or 4 degrees. If the driver needs cooling in near freezing conditions, what size hole will be required at hot races? #-o #-o
Re: Ferrari F138 nose hole
I think this slot is integrated on the nose.
So it is easy to change configuration with different faces
Look on my twitter
https://twitter.com/Graftechweb/status/ ... 08/photo/1
f1316
f1316
82
Re: Ferrari F138
It actually occurs to me that Massa complaining about the lack of cooling in the cockpit might be a clever way of suggesting that the *primary* purpose of this duct is cooling - when it fact it will also have a secondary effect...
Ferrari do keep talking about pushing the rules, like they perceive RB do
EDIT: Sorry, didn't see that this was already pointed out. Carry on...
Redragon
19
Re: Ferrari F138
I think this analysis is a bit better than the one done by the expert Mr Anderson.
http://www.bbc.co.uk/sport/0/formula1/21390731
Nando
Nando
zioture wrote:I think this slot is integrated on the nose.
Look on my twitter
I thought holes in the nosecones was illegal, hence the reason Red Bull made half a hole last year.
FrukostScones
162
Look on my twitter
maybe there is a loophole in the regs, or it is just in the regs that you can't have one in the tip but in the next box
aral
aral
26
Look on my twitter
Interesting. I never knew that there was such a thing as "half a hole". =D> =D> =D>
zoro_f1
-2
Re: Ferrari F138
this is from day 3 in jerez. there is no whole on massa car. than why he said that it was for cooling the driver when he doesn't have it? that "misterious" whole was only on De la Rosa car next day.
Image “The force can have a strong influence on the weak-minded”: [Obi Wan Kenobi]
Nando
Nando
Look on my twitter
yea yea yea you know what i ment :)
.poz
.poz
50
Nando wrote:I thought holes in the nosecones was illegal.
Ferrari hole is not in nosecone, is almost aligned with front wheel center
Nano_F1
Nano_F1
Re: Ferrari F138
Maybe this image can help us to see the hole.
