Khamsin Virtual Racecar challenge 2013 (CFD model racing)
N12ck
Re: F1 model CFD Challenge (Khamsin Virtual Racecar challeng
RicME85 wrote:Email \o/
Have to use the supplied crash structure? :( Looks like a redesign of my rear end then...
yes, as some teams didnt have it, some teams crash structures were completely illegal, so to overcome this issue I supplied all internals
Budding F1 Engineer
RicME85
52
stock championship :(
Not too big a deal as I only have a small percentage of my car done, I have lost creativity recently due to a number of personal issues, I was hoping for inspiration from the car launches but nothing came, hopefully Williams produce something weird and wonderful for me to take ideas from.
At this rate I will be running my car from the test but with a modified tub for legality.
remydio
remydio
Thanks, i ve received my welcome pack, going to work with it now :wink:
cdsavage
cdsavage
19
There are some issues with the supplied tub file.
The measurements that the regulations state should be made from the "rear of the cockpit entry template" have, on the tub file, been made from the rear of the opening with the padding fitted. Those measurements (eg the floor exclusion area) are too far forward, so the leading edge of the floor on your tub file is too far forward. This also means the front bulkhead is slightly too far forward since the measurement for that is made relative to the rear of the cockpit entry template.
RicME85
52
I thought something was up when I made my tub and compared it to the supplied one.
N12ck
Richard, your tub was the wrong size completely at the front end of the tub, as for the floor measurements, I can only apologise for this, what had happened was I copied the floor measurements from my other model as I thought my 2 models I had were the same, I will correct this for you all,
Thankyou for pointing this out,
Budding F1 Engineer
astracrazy
astracrazy
31
my car is currently based on the tub from v1 (obviously be adding in the v2 engine,gearbox, crash structure) will my measurements be correct?
Mclaren340
Mclaren340
Could you add the wheels and suspension to the pack so that we can run cfd on the car?
RicME85
52
it would be nice to have them just so we can render pics without the car looking silly or having to mock up our own.
astracrazy
astracrazy
31
ye would be good
RicME85
52
astracrazy wrote:my car is currently based on the tub from v1 (obviously be adding in the v2 engine,gearbox, crash structure) will my measurements be correct?
Tub from V1 is the same as from V2, I have just C+P'd them side by side and they match up
seventhsin
I registered a team days ago and have not received a confirmation email or the welcome pack.
N12ck
seventhsin wrote:I registered a team days ago and have not received a confirmation email or the welcome pack.
You only registered a few days ago, aside from this I have not had time to process it due to being in hospital with a broken ankle, so apologies for not getting the email to you in time,
Budding F1 Engineer
N12ck
yes it is, minor adjustments + new internals, why fix something that isn't broken :D I will address the floor issue
Budding F1 Engineer
RicME85
52
the cockpit dimensions that came into question are a perfect match though
