Chuckjr wrote:bhallg2k wrote:More likely ballast.
What is ballast made of on this car, and how much would a piece like that weigh? How many would be typically located on the car and would they be different weights between the right and left side if equidistant from the centerline of the car, and a longitudinally parallel location?
I dont think they place much weight left or right, mostly because of body roll. It could be that they use slight weight differences left or right.
The ballast was from a metal, I believe it was called tungsten, but I am not sure, it weights the most per m² iic.
