For my model I want the rear wings to abide by regs. I am having trouble understanding these, though. If someone could help me out by explaining these regs a bit I'd appreciate it. http://www.fia.com/resources/documents/ ... ations.pdf
JB
yeh, they were there last year as well if I remember correctly.I've never understand why the drawings are labelled 2005 technical drawings at the FIA site. Haven't they published the 2006 version? Are they the same? Thanks in advance if anybody can answer my doubt.
That part seems to describe what is in between the two outer plates. What does it mean? Does the "be identical" part mean that the elements must not curve like the front wing does?With the exception of 10mm on each of their outer extremities and 25mm on each of the inner
extremities, within these areas bodywork may lie no less than 740mm above the reference plane and
315mm behind the rear wheel centre line. When viewed from the side of the car, all longitudinal cross
sections in this upper area must :
- be identical ;
- be arranged in order that their rearmost points are no less than 695mm behind the rear wheel
centre line or 965mm above the reference plane ;
- contain no more than three closed sections, the distance between adjacent sections at any
longitudinal plane not exceeding 15mm at their closest position.
Any horizontal section taken through bodywork located in the areas 515mm to 540mm and 990mm to
1000mm from the car centre line may contain no more than one section which is symmetrical about
its major axis which in turn is parallel to the car centre line.
Yeah, I meant to say that Jagboy's wing elements look too far apart (in a biplane configuration) which is against the rules that specifies "max 15mm" apart. Also the wings are curved, which is against "identical cross sections"Ciro Pabón wrote:it says "no more than three". Two is "no more" than three.
You're obviously more imaginative than I am... when I read this I immediately thought "flat wings!" but yes, obviously, you can curve the wing and maintain the same cross section. I think we've found a gray area here. However, "identical cross sections" should mean the end of fins, spacers, and whatnot on the wings.Ciro Pabón wrote:However, "identical" does not give you much margin. Probably, they must have not only the same thickness but also be located in the same position in the cross section, which means flat wings.
Hmmm... sounds like endplates to me. "One closed section", right? That also means no more cutouts or grilles in the endplates. "Symmetrical about a horizontal axis" simply means the endplates can't curve inwards or outwards (ie. left or right), it has to be straight front to back.Ciro Pabón wrote:What I find mistifying is the part about the sections taken between 515 and 540 mm (and 990 to 1000) from the center line to have just one section, simmetrical and with an horizontal major axis...
