Love the view. Very fluid.Forza wrote:
Does anyone know the reasoning behind the "fangs" on the rear of the engine cover? Perhaps bodywork to fair in a DRD periscope?
Forza wrote:
I believe they are trying to channel the air through the wheel nut so they get a better flow on the outside of the wheel.Carbon wrote:Can anyone explain how the 'blown wheelnut' works? Does it extract and vent hot air from the brakes, routing the air outside of the wheel, vs inside it?
it wont make any difference to the wheel gun. the nut is still the sameRikhart wrote:I bet that will cause some problems in pitstops, it looks much harder to fit the gun into, than regular wheel nuts.
isnt it blowing the tyre? as behind the tyre creates a low pressure area (more drag) so by blowing it. it removes the drag right?Sevach wrote:I believe they are trying to channel the air through the wheel nut so they get a better flow on the outside of the wheel.Carbon wrote:Can anyone explain how the 'blown wheelnut' works? Does it extract and vent hot air from the brakes, routing the air outside of the wheel, vs inside it?
It's basically what those wheel covers used to do a few years back.
