BlackMercedes wrote:Is it just me but do the side-pods look more dynamic than before or is that just the new sticker???
via SomersF1/Sutton Images
Mercedes W04 - Rear End detail, nothing new just a good shot of the Diffuser and Gurney (Note still no Rear Wing Endplate Strakes for Mercedes)
cause they wanna win?Joie de vivre wrote:they've been using this endplate for years now. why change it now? hahaha
Do you have evidence that it performs poorly?Joie de vivre wrote:they've been using this endplate for years now. why change it now? hahaha
That's one way of looking at it but if you look at in a more optimistic way you could say that every car on the grid will be missing something that another top team has.Joie de vivre wrote:no i don't but, look it this way -> red bull uses strakes, mclaren uses strakes, ferrari uses strakes. and those teams were (and probably still are) better than merc
do you think merc will gain more rear downforce with those rakes?Joie de vivre wrote:no i don't but, look it this way -> red bull uses strakes, mclaren uses strakes, ferrari uses strakes. and those teams were (and probably still are) better than merc
there has to be difference with endplates with and without strakes, obviously, so if we presume that non-strake endplate is better, why would top team run with strakes? The thing is, they haven't even try to test the version of endplate with strakes
but again, no, i don't have evidence
The problem with this is simple – you can't beat people simply by copying them. You have to go down your own path and find a solution that works, because if you just go "well, they did that and it worked" you're doomed to be 3 months behind them.Joie de vivre wrote:no i don't but, look it this way -> red bull uses strakes, mclaren uses strakes, ferrari uses strakes. and those teams were (and probably still are) better than merc
Most likely because they have computer simulations and wind tunnels, and because it turns out that simple intuition is not as powerful as these devicesn smikle wrote:The end plate guide vanes allow the air to flow faster between the endplates and diverge outward behind the rear tyres thereby enabling the diffisur to work more efficiently.
It's a no-brainer in my view... I really wonder why merc have not implemented it?
"enabling the diffisur to work more efficiently."n smikle wrote:The end plate guide vanes allow the air to flow faster between the endplates and diverge outward behind the rear tyres thereby enabling the diffisur to work more efficiently.
