While that's true, we've seen both inserts...
Pay no mind to the arrow; it's not mine.
...and veils shielding the radiators from direct flow.
bhallg2k wrote:[...]
(Right click to enlarge)
The only topless picture I've seen around here is this one. But, given everything, it doesn't appear the team are very concerned with direct flow onto the radiators.
Now, I have no idea what any of this...
forza wrote:I wanted to point out that it's a trade off between cooling efficiency and drag. The diffuser geometry controls the velocity of the air flow and aims to prevent the separation. Ideally you would only create turbulation at the core surface to enhance thermal transfer. The cooling core efficiency itself depends on three parameters; core pressure drop coefficient, velocity ratio and drag coefficient of the core.
...means in that context, because I'm not that smart. But, what I do know is that if the inlet chokes, nothing that happens within the sidepod behind that choked inlet matters anymore as far as the car's external aerodynamics are concerned. It's as if it all disappears, and the sidepod becomes just another bluff body being dragged through the air.
This would be
very helpful for a car with top speed issues.
Ferrari has clearly improved the [F2012] a lot in traction out of low speed corners, which helped in Barcelona and Monaco and will help out of the chicanes and hairpins of Montreal. However another key weak point is straight line speed and this is not straight forward to fix.
(Tell me about it!)
However, there are obviously risks to running such an aggressive cooling strategy...
diemaster wrote:
bhallg2k wrote:Gearbox, was it?
Such risks would be eased considerably by larger sidepod vents...
Forza wrote:[...]
BCN T03 Day 3
...combined with an auxiliary inlet to help kickstart, if you will, the system back into action.
Basically what I'm trying to say here is that I think they're "stalling" the sidepods.
