Help with Khasmin
andylaurence
123
Re: Help with Khasmin
Should it work without openmpi? Does it matter that it can't find it?
RicME85
52
I have no idea where that is referenced in Khamsin.
Have you gone into the KVRC thread and downloaded the Ahmed Complete .skp and ran a simulation with that, making sure that swak4foam and groovy is turned off?
andylaurence
123
Ha! Looks like it's not required at all. I have results and I can open them in Paraview. Unfortunately, I have now realised I need to learn how to interpret them.
astracrazy
astracrazy
31
just installing khamsin now but the ensight tool link is broken, anyone know what it is
RicME85
52
Even though I have PM'ed you I thought I would post to let everyone else know, EnSight is not needed. It is for viewing results but Paraview does that. EnSight free cannot handle the large file sizes involved anyway.
kosioBG
86
found almost everything, just the Openfoam library linkis broken, and it doesn't work without them. Ideas?
RicME85
52
the directory you need to add will be program files -> blueCFD-SingleCore-2.1/OpenFOAM-2.1/etc/batchrc.bat"
kosioBG
86
Let me be more precise- i followed your steps and downloaded and installed paraview, gnuplot, gmsh and curl. Further down, it requires a bunch of openFoam things. I know how to tell the program where they are, but i don't have them, i need download links. and, please tell me if i've installed the correct third party apps, and what else i need. thanks.
RicME85
52
if you cant download the openfoam bit through Khamsin then the link you want is - http://code.google.com/p/bluecfd-single ... e&can=2&q=
kosioBG
86
Thanks, i got it running. Now i just lack knowledge of what to do with the results, any tips welcome
CottrellGP
CottrellGP
Is there any guides for dummy how to install it from step 1 to the finish?
Dan Cottrell
Master Of Innovation!
kosioBG
86
CottrellGP wrote:Is there any guides for dummy how to install it from step 1 to the finish?
yes i'll post one as soon as have some time :D
CottrellGP
CottrellGP
Brilliant, thanks! :D
Dan Cottrell
