They changed hamilton's rear wing in Monaco in about 5 minutes before if i remember correctly. And that was a very technical pull down and refitting, which was done on the grid. Mechanics had to be going back and forth.Neno wrote: its not possible to change rear wing in two minutes, unless it's constructed and complete seperate from gearbox on who is going beam wing and rear wing. Rear wing is not front wing. Also his rear wing was not damaged that way that rear wing broke completly, it looked after kick in wall as one plate of rear wing was just loosen off and started going left-right.
2 minutes is reasonable, depending on the damage.
