Well, I disagree. Look at this photo, there are obviously some wires going to this part.
http://i.imgur.com/1erzX0e.jpg
This.Low_drag wrote:I think the so called IR camera that's on the corner of the side pod next to the vertical fins is merely a bolt head to hold the vertical fins onto the side pod. I keep seeing that question come up. I think sometimes our imagination gets the best of us, but it's also what creates innovation.
bhallg2k wrote:I really don't know. The part of this thing that bugs me - an aspect I willfully ignored last night when I proffered my harebrained theory - is that any fuel is going to ignite on contact with any part of the exhaust, because it gets so damn hot - red hot, in fact. That's obviously going to make even very temporary "storage" of fuel a real problem.
One thing the Helmholtz chamber can do, however, is tune the Kadenecy effect of the exhaust at specific engine RPM ranges. So, maybe the whole thing is as simple as retarding ignition, as allowed by 5.6.6, at an RPM range that the engine would tend to hit just prior to a downshift. In that way, the exhaust system would scavenge that little bit of unspent fuel, which would ignite and energize exhaust gasses during the downshift. That's when you'd want the added downforce anyway.
Well on the link Mr G suggested there is a picture of one of this company's cameras next to what looks like a penny. (I'm not being sarcastic, i literally havent seen a US penny in a while) the diameter of the "lens" doesn't look much bigger than the penny. that looks pretty much on the order of size of what we are looking at. also don't forget, these aren't IR Cameras attached to sights like the military.Low_drag wrote:That's funny, those were from L3, which was our main competitor for military products. Those things are huge compared to the feature on the side pode turning vanes. Trust me, those are not IR camera's. I think it would be a valuble data tool, but why not just have someone in the pits use a thermography camera to capture tire temp data down the pit straight. It would be alot less complicated and less costly to implement. If that is an IR camera, then they have more sophisticated equipment than what's on our thermal weapons systems here in the states. I was designing them up until last year.
That wire looks very much like coaxial cable and an associated connector. If it was a strain gauge, pressure transducer or thermo couple you wouldn't need that kind of signal shielding.Mr.G wrote:Well, I disagree. Look at this photo, there are obviously some wires going to this part.
Maxion wrote:Speaking of cables, there it is again! Thanks stefan_!
