siskue2005 wrote:What is the purpose of the bulge just before the exhaust ramp and also on the floor?
does it reduce some boundary layer? and attach some air?
is it the same thing which some teams run under their nose? to remove boundary layer?
http://i.imgur.com/1YarXxW.jpg
Australiaperformergr wrote:
stefan_ wrote:
via Craig Scarborough
As I know every mayor team has a group of people back home, watching live the race and all the telemetry. They are there to help making strategy decisions. The theory behind this is that because they are not at the actual race are able to make decisions with a "cold head". So I can not understand how this complicated decision making system has no chassis guy who could veto these kind of decisions based on his better knowledge. BTW, I still did not read or hear any comments other than: "I was sure they will change his front wing in the first lap".wesley123 wrote:Making such a decision is never possible imo. That you need to make such a decision in an instant is just not feasable to do, since there are so many variables to take care of, making a decision then is more based on luck than actual knowledge. And then, if the decision had worked out, the team would be a hero for that, however when it doesnt work out, they suck.
And another interesting things that it seems Alonso and Massa used different engine cover in the Malaysian GP. Alonso with additional cutout for Vertical Rad cooling and Massa has no additional cutout for cooling other than the new engine cover exit.Autosport Plus wrote:Malaysian GP technical round-up
Ferrari
Ferrari's diffuser has gained a new channel under the rear crash structure.
Modified diffuser for Ferrari © XPB
For better reference >>>
Much like the Mercedes solution, this is a way to circumvent the rules that limit the diffuser to a 125mm height and the ban on openings in the diffuser.
In the middle of the diffuser, a dipped channel is visible. The scoop formed by this dip is legal as its opening is formed by an extension of the starter motor hole.
Above this scoop, the diffuser rises to about 200mm, far more than the 125mm maximum height. The scoop masks this height and forms the surface that meets the height regulations.
To make this duct produce downforce, airflow needs to pass over it. This is probably the flow that passes tight against the sidepods, coke bottle shape and up over the middle of the diffuser.
Although this duct creates a little more volume in the diffuser, it isn't another form of double diffuser. The potential of the extra duct is limited by the crash structure mounted above it. So this diffuser channel is not likely to become a must-have addition for all teams.
