slimjim8201 wrote:BreezyRacer wrote:So he feels that CFD has a ways to go in fully explaining and emulating ground effects aero.
In any case if you would like an exercise to run, try a 55"x60" flat bottom with a 15"wide x 30" long diffuser at 10 degrees, and 2" of ground clearence. Velocities of 1.5ms, 3ms, and 5 ms.
He is referring to the inability of CFD to analyze the many transient phenomena that occur as the cars go through their very dynamic motions. Braking and acceleration pitch, cornering roll, etc. It's not so much that it can't be done, it just hasn't been done yet. Regardless, CFD remains FAR FAR FAR more efficient as a design tool than a wind tunnel could ever be. The cost of building numerous prototypes or implementing many design changes for wind tunnel testing is always going to be more expensive than analyzing the models in a CFD code. No, you won't get 100% accurate results, but no one expects that and frankly no one needs that. The correlations found in CFD codes (ie the percentange changes among many designs) ususally translate to real world data VERY well. Final testing should always be done in a wind tunnel, but CFD should be the foundation.
...unless, of course, you really like wasting time and money...
Well said, though I think you underestimate the importance of wind tunnel/testing. No matter how great CFD is, without experimentation you are still guessing as to accuracy. You NEED a heavy commercial CFD code like Fluent to get great accuracy and you NEED very skilled and specialized people and big computers. All of these are very expensive! Also, you do not need to build a tunnel, just rent time in one . . .
You say CFD is far more efficient, but that's not always true. What if you already have a tunnel and expertise to run it, but not the clusters, software, and CFD experts? What if you are partnered with another company or university that offers you tunnel time without the cost of building your own? How much does a well versed CFD engineer cost you? How much do good commercial packages (not floworks et al) cost you?
But otherwise, yes, CFD can model trays well. To address breezy's points from Xin Zaung:
separation as a normal feature
• suspension motion leading to unsteady flow
• highly complex physics: wall jet, shear layer instability, vortex
meandering and breakdown, etc.
• force enhancing vortices
• turbulent wake and ground boundary layer interaction
• compressibility
Maybe Mr. Zhang wrote his paper when computing power wasn't high enough to solve the reynold's stress equations for anything but course grids over simple bodies, but, other than using simple spallart-allmaras models, the Re stress eqn's and even the K-omega and K-epsilon models can predict stall quite well if implemented correctly.
The navier stokes and Re stress eqn's can handle the complex physics you described. It's whether or not the grid can!
Force enhancing vortices can be captured with the proper grid. Heck, using crocco's theorem (relates enthalpy to vorticity) you can even model vortical elements (like propellers) rather well using inviscid panel codes!
Turbulent wakes and boundary layer interactions have been captured by CFD for a while. shock boundary layer interactions (shock induced separation sticks out here) can be captured with rather course grids in fluent for example. I can show you some examples if you wish.
Compressibility is easily modeled in CFD.
Perhaps Mr. Zhang's evaluation of CFD for the undertray is dated?[/b]
