Ferrari F138
Re: Ferrari F138
China 2013 - Friday (12.04.2013)
PABLOEING
PABLOEING
Re: Ferrari F138
f300v10 wrote:So other than the new front wing and turning vanes I can't see any other outwardly visible changes. I haven't found a shot of the diffuser area yet to compare, but it looks like the aero work is concentrated at the front of the car. The rear wing appears identical to the last race.
Ferrari have a new floor and difuser in this GP......
F1.Ru
21
Re: Ferrari F138
Crucial_Xtreme wrote:Fernando & Felipe using the new FW with 2 slots in the endplate footplate
http://formula1.com/wi/enlarge/sutton/2 ... chn983.jpg
http://formula1.com/wi/enlarge/sutton/2 ... 4ap282.jpg
Sutton
Yes IIRC this is a completely a new thinking philosophy for FW in a part of Ferrari. Caz every other team are trying to send the air outside of wheel wake where Ferrari is trying to scoop some air inside the wheel. May be its directing air towards the Front wheel break disk. Or as a wild guess Ferrari might trying to replicate some of the Flex wing solution with this as car speed rise so does the air flow around the tyre. so with angled FW they will bend the tip of FW as well as the whole FW toward the ground. But the burning question is how they are mitigating the problem of drag in high speed. Think that F138's FW is designed with remembering this concept. As the high speed air started to create drag problem by lowering the FW towards ground, so Ferrai's FW must stall somehow to negate that effect. :?
Whatever the simplest answer is it might just create vortexes which leads the air toward the sidepod turning vent. which ever is correct Mr. Gary Aderson will not be happy with this caz last year he just criticized Ferrari for immature FW design regarding their FW endplate now Ferrari is not only continuing with them but bringing further conflicting concept. :lol:
Some more from Practices -------
Alonso is back-to-back comparing the New FW and previous one :
OLD
New
© Formula1.com, Sutton Images & F1fanatic
Formula One is a game.............. but not any ordinary game for me
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F138
Ferrari new FW Analysis & flo-viz from Piola
Link to Analysis
F1.Ru
21
Re: Ferrari F138
Crucial_Xtreme wrote:Ferrari new FW Analysis & flo-viz from Piola
http://img194.imageshack.us/img194/2977/f138chn.jpg
Link to Analysis
Thanks X2 for the link.
It seems that my idea was not that far from Piola's interpretation. Still question is how F138 is stalling the FW in high speed :?: Caz F138 is showing very good speed in all of the races so far in the speed trap.
F1.ru wrote:Or as a wild guess Ferrari might trying to replicate some of the Flex wing solution with this as car speed rise so does the air flow around the tyre. so with angled FW they will bend the tip of FW as well as the whole FW toward the ground. But the burning question is how they are mitigating the problem of drag in high speed. Think that F138's FW is designed with remembering this concept. As the high speed air started to create drag problem by lowering the FW towards ground, so Ferrai's FW must stall somehow to negate that effect. :?
shelly
shelly
136
Re: Ferrari F138
Just read a comment on twitter from @f1_aero saying that ferrari triple element under nose barge board aim does create a cleaner vortex than a single leading edge. So that's probably the same aim for the e21 slotted bargeboard.
Back to ferrari fornt wing, they had a different philosophy last year also, placing small slotted inlets on the endplate side, where other teams (notably williams, for example) have big outlest. With inlets I mean guides for the flow to come from the outside to the inside of the wing - desing that could be helpful to mnake the inner part of the wing work better in yaw.
Now that i read the article on omnicorse, it seems similar, except they say that mclaren and redbull were doing the same last year whereas they wer doing the opposite (outlets on the endplate opposed to ferrari's inlets.
Any way it seem that omnicorse rely on a good source - f1 aerodynamicist; the idea that wing flexing helps with tyre vortex management is not new though, it has been talked from a year or so
twitter: @armchair_aero
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F138
It seems the first slot in the foot plate is helping to send some flow inward and below the wing while the rear slot is actually getting some flow from inside the FWEP.
via Sutton Images
7 Element FW is above & beyond the others as well. Interesting how they are working their FW
via Sutton Images
Forza
238
Re: Ferrari F138
China GP - Saturday - 13/04/2013
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F138
Piola reports the outer gurney flap has changed.
via OmniCorse.it
Link
Hail22
144
Re: Ferrari F138
http://www.omnicorse.it/img/articoli/ev ... eriore.jpg
via OmniCorse.it
Link
Translation of Piola's Article:
Ferrari has also changed the rear diffuser recovering of the concepts we had already seen on the F2012 last year in the second half of the season: the Gurney flap that "frames" the extractor now has a more rounded in the outer part, revealing also a greater inclination of the side wall.
The F138 in China is proving to be a machine that has recovered the downforce that seemed to be lacking and is especially noticeable in the exploitation of soft tires: Fernando Alonso managed to close the fastest lap in FP3 maintaining an excellent step in the third sector, where other machines are already in crisis.
Gilles Villeneuve
Ludus
Re: Ferrari F138
hi guys. have someone noticed if the upgrades bring in china were used in qualifying ?
f300v10
f300v10
185
Re: Ferrari F138
Ludus wrote:hi guys. have someone noticed if the upgrades bring in china were used in qualifying ?
The front wing and turning vanes were used. However Alonso mentioned some of the parts they brought did not deliver. Not sure what those parts were, and they may not have been visible I.e. not bodywork.
flyboy2160
flyboy2160
84
Re: Ferrari F138
it may have been "fix it again, tony" at times in the past, but this year's carbon fiber quality looks stunning to me! (I believe another poster also pointed this out previously.) thanks to all those posting the close up pictures.
f300v10
f300v10
185
Re: Ferrari F138
via OmniCorse.it
Below is from Malasia, and I can't see any difference in the diffuser or Gurney. It clearly changed between rounds 1 and 2, but I'm not convenced it has changed again for China.
timbo
timbo
111
Re: Ferrari F138
It is incredible how tiny modern gearboxes are!
