Crucial_Xtreme wrote:shelly wrote:
Yes it is - in the sens that teams try to have the most flexible floor they can in front of the rear wheels, because it gives a big aero advantage.
Shelly, perhaps you can explain why it gives an aerodynamic advantage to have the floor flexing by rear tyres/flow corners?
I'll be glad to hear more on the subject, but generally when car is cornering there's a lot of pressure going on at the sides of the underbody, as opposed to the straight line.
In F1, when it comes to floors, lots of downforce is being generated at the leading edge of the floor and near the diffuser, of course. At the same time, since skirts are not allowed in any form, the air that's bleeding from the sides of the floor is better to be moved out of there as fast as possible, thus creating another low pressure area. This would be similar to Venturi effect, but on the sides - to achieve that, you need a floor that's bending upwards, resembling a diffuser exit.
Also, when cornering, the underside area ahead of the rear tires has some quite strong vortices being generated - the stronger they are, the bigger the downforce would be. Also, if you can control those vortices and prevent the "bubble burst" you would be in a good position to induce some additional downforce. This would match the curved side of the floor development that Ferrari had for a while.
In this case, however, the oscillation was too severe, IMO, so I'm not sure that's the desired effect. Let's see some more footage.
