Mercedes AMG F1 W04
Shakeman
33
Re: Mercedes AMG F1 W04
richard_leeds wrote:
kilcoo316 wrote:Do they have a thread to dump their woes in?
This thread is intended to focus on the actual features of the car. We have the team thread thread for talking about the team, and the race thread for talking about the laptimes and tyres in the race.
Richard where should we discuss car performance?
The discussion crosses over very quickly from new bits on the car to performance implications but there doesn't seem a suitable place to discuss this aspect of the car.
Where should the more broader discussion relating to the car go please?
MercAMGF1Fans
MercAMGF1Fans
From OmniCours..
tranlated to english - New rear suspension for the next race
http://mercamgf1-fans.com/2013/05/17/ne ... or-monaco/
kilcoo316
kilcoo316
21
MercAMGF1Fans wrote:From OmniCours..
All the teams will probably be looking at revised suspension from Canada onward. Unfortunately Merc may only get one weekend out of their hardwork!
beelsebob
beelsebob
85
The question is, does the revised suspension require revised mounting points? If so, Lewis may be out of luck, as he had a gearbox change too early.
MercAMGF1Fans
MercAMGF1Fans
you say that, but if they're going back to the 2012 spec of tyres in Canada, then surely they have the data available from last year's race and so on, so they'll be optimizing the new suspension for the 2012 spec? mind you last year the problem was that they didn't have Coanda exhaust in Canada
Richard
Richard
Shakeman wrote:The discussion crosses over very quickly from new bits on the car to performance implications but there doesn't seem a suitable place to discuss this aspect of the car.
I agree, discussing a feature is bound to include discussion about drag, downforce, mechanical grip etc. That's fine.
Recent moderation has been to remove laments about about race strategies, team management, "this car is rubbish" and so on.
To be honest, go with the flow.
kilcoo316
kilcoo316
21
MercAMGF1Fans wrote:you say that, but if they're going back to the 2012 spec of tyres in Canada, then surely they have the data available from last year's race and so on, so they'll be optimizing the new suspension for the 2012 spec? mind you last year the problem was that they didn't have Coanda exhaust in Canada
The front tyres are still different... so the exact same rear suspension geometry (which need I add, didn't work too well last year), will not work this year. Some changes will be necessary.
Dreameagl
Dreameagl
beelsebob wrote:The question is, does the revised suspension require revised mounting points? If so, Lewis may be out of luck, as he had a gearbox change too early.
Doesn't the new design with a mounting frame around the gearbox allow for just that? Namely a change of suspension geometry without changing the gearbox.
beelsebob
beelsebob
85
Oh really? I hadn't realised that that was what mercedes were doing. I had heard early on that they had "more flexible" suspension this year in testing, but hadn't seen anything about exactly how it worked.
Do we have any pics of this mounting frame?
If that is the case, I do not think mercedes had to change lewis' gearbox at bahrain; the frame would have taken the hit.
I do know Ferrari is using a frame.
otbsti
turbof1 wrote:If that is the case, I do not think mercedes had to change lewis' gearbox at bahrain; the frame would have taken the hit.
Lewis' gearbox was changed at Bahrain due to the damage from the tire to the gearbox. That's why he started 9th.
"Winning is the most important. Everything is consequence of that."
-Ayrton Senna
Mercedes AMG Petronas
Lewis Hamilton #44
Yes, because the suspension is attached to the gearbox. Damaging the suspension could cause damage to the gearbox too.
Of course, it could also be that the driveshaft got damaged (and in turn damaged the gearbox), in which case a frame would not have mattered.
MacX
TYRE CHANGES WILL BE MINIMAL. Not good for mercedes
http://www.autosport.com/news/report.php/id/107475
beelsebob
beelsebob
85
Indeed, my assumption was that the damage was not that the suspension flapped around and hit the gearbox causing damage, but instead that the drive shaft got wrenched out of the gearbox, and trashed a bunch of gears as it did it. A frame to build the suspension on would not solve that issue. Do we know if Merc have such a frame?
This image from earlier in the thread certainly seems to suggest that at least the upper wishbone attaches to some structure above the gearbox. The lower wishbone is a bit more ambiguous.
240
Do we have any more shots of the gearbox?
