mep wrote:I think you got something wrong ringo. I never heard anywhere that the system uses the hydraulic compression as spring. In fact that would be way too stiff and difficult to adjust. The point of our previous discussion was that the compression of the fluid can’t be neglected.
People have been saying that if you follow some of the discussions!
The thread has evolved to a point none of us here believe the system has no springs at all, but i was just looking into the damper itself. I can assure you though that there's still a small contingent that would believe anything once it's in a blog. So i was just trying to make the clarifications in this thread.
Even with the interlinked suspension it is IMHO best to use conventional steel springs. What the links do is only to distribute the load to several corners of the car. It might offer new options of pitch and roll damping as well.
Basically it goes like this: A load applied to one end of the car is supported by the springs of the other end. A compression of the front axle for example causes the rear to compresses as well. The compliance of the link and the different spring stiffness’s determine how much.
I am in agreement of this, but read some of the blog articles out there, even ones sited wherever fric is discussed, and there are suggestions that Mercedes aren't using any springs whatsoever and Lotus are to follow suit in upcoming races.
Right now, i'd like to see a nice FRIC diagram, with the ride height adjustment. I have a semi mechanical method for the ride height that doesn't involve bleeding or the fuel tank weight, but it depends on "track memory". It jacks down under big braking events.
Especially since these are mostly at the end of long straights on a track and happen once or twice per lap, it acts as a good jack down clock.
I'll sketch the mechanism.
