gcdugas,
Probably only Ferrari know the real answer to your question about injector placement, but I'll hazard a guess;
A key element in maximising efficiency of combustion is to have a homogeneous charge in the cylinder. High injection pressures are used to atomise the fuel; making the droplets as small as possible gives a high surface area:volume ratio enabling rapid evaporation of the fuel droplet in the inlet charge. GDI (gasoline direct injection) is something the commercial engine manufacturers have been working on for some time, so far with limited success, but again homogeneity of charge plus avoiding knock is a perpetual issue.
In any case the regulations state that the injectors must be placed in the intake;
5.7.1. The pressure of the fuel supplied to the injectors may not exceed 100 bar. Sensors must be fitted which directly measure the pressure of the fuel supplied to the injectors, these signals must be supplied to the FIA data logger.
5.7.2. Only one fuel injector per cylinder is permitted which must inject directly into the side or the top of the inlet port.
In an F1 engine the revs are so high I doubt direct injection could function efficiently unless injector pressures were extremely high, as the pressure is limited the degree of atomisation is also limited. For the engine you were looking at, situating them further out a) gives the variable intake trumpet space to move, and b) permits maximum time for the fuel to evaporate completely (even at 20k rpm).
That's my 2c on the question.
