That sound more like a point against the decision to put the electric torque through the engine.Dragonfly wrote:Isn't this because initially the intention was to drive the cars on electric power only in the pit lane?
Mainly because with the MGU-K on the front of the crankshaft it was not possible to use electric drive without also turning over the ic engine.Dragonfly wrote:Yep, but you said you thought the MGU-K was supposed to drive the wheels (independent of the ICE if I understood it right). And this might have been the case in earlier state of the rules. Then they abandoned the idea of electric only drive, I am not sure what the reasons were.
Maybe the torque numbers are enormous, but not the power numbers i suspect.Blackout wrote:http://motorsport.nextgen-auto.com/2014 ... 62936.html
The engine makers Renault, Mercedes and Ferrari are understandably holding their cards close to their chests, but Schmidt reports that Pirelli is expecting cars with full boost next year to be propelled in qualifying by up to 900 horse power.
And torque is set to increase dramatically, to 600 newton-metres.
Pirelli’s Paul Hembery said: "At the moment we don’t know exactly what to expect. "But the numbers we are hearing are enormous"
So what do you think of the numbers that I have put together? 600 Nm IMO implies that they will be well over 800 hp which you have doubted so far. In fact I'm getting 885 bhp for 600 Nm @ 10.500 rpm. One possible explanation is the inclusion of a safety margin in the torque figure. I would include at least 10%. That would indicate they were expecting 800 bhp.xpensive wrote:What would be of a concern to Pirelli is of course the wheel-torque, which is dependent on power and nothing else.
Yes, agreed. I think the torque figures would include a safety margin that you would have to deduct. But 800 bhp is right in the zone that Marmorini from Ferrari predicted. Hence I believe that we will be seeing it during the next year.xpensive wrote:800 Hp, total, should call for 637 engine such, asking for an efficiency of 36.6%, which would make a little more sense?
Remember it's a turbo engine, so things won't be linear. The peak torque wont be in the same area as the peak power.WhiteBlue wrote:So what do you think of the numbers that I have put together? 600 Nm IMO implies that they will be well over 800 hp which you have doubted so far. In fact I'm getting 885 bhp for 600 Nm @ 10.500 rpm. One possible explanation is the inclusion of a safety margin in the torque figure. I would include at least 10%. That would indicate they were expecting 800 bhp.xpensive wrote:What would be of a concern to Pirelli is of course the wheel-torque, which is dependent on power and nothing else.
I think you have missed some of the efficiency discussions we had on this and other threads. The V8s had 29% according a broad agreement by several people familiar with the issue.ringo wrote:They will get nowhere near 41% efficiency. Maybe around 27% thermal efficiency. It cannot be greater than the Carnot efficiency if i'm remember correctly.
