No this is just for example.WhiteBlue wrote:These figures are not consistent with your earlier computations, are they? Also 120 kW has never been discussed as a realistic load for the MGU-H. It is the peak power allowed for the kinetic machine. But we would not expect the heat regeneration to come close to that level, do we?ringo wrote:Something to think about for the MGUH.
If a turbine has 300hp available to do work and the compressor needs only 50hp. The MGUH can draw a maximum of 120kW with full batteries.
Both of these are loads on the turbine.
Do you think that if the turbine was spinning freely at 100k rpm, adding 120kW will somehow prevent the compressor from getting it's 50hp?
It may delay it once the torque of the MGUH is on the shaft, but it's going to creep up back and meet the load demands as long as that demand doesn't exceed 300hp.
That's the thing with the MGUH, it's a load, it's not pressure relief. Turbines operate on pressure difference. Mass flow must be manipulated to control enthalpy. In order to limit boost it must take a lion share of the available power leaving the compressor to take the scraps.
It's possible depending on how much available power is there, but i still see the waste gate as more viable and less complicated. chances are the MGU wont be able to control boost how we would like.
So what do you think is the HP available on a "radial" not axial turbo for the MGUH after the compressor has taken its share???ringo wrote:No this is just for example.WhiteBlue wrote:These figures are not consistent with your earlier computations, are they? Also 120 kW has never been discussed as a realistic load for the MGU-H. It is the peak power allowed for the kinetic machine. But we would not expect the heat regeneration to come close to that level, do we?ringo wrote:Something to think about for the MGUH.
The MGUH will have a lot of energy available, but i think the turbine efficiency at certain speeds will have a big influence.pgfpro wrote:
I come up with 40HP compressor drive pressure and 40HP available for the MGUH with zero waste-gate flow. All of the exhaust going through the turbine!!!
to be blunt, why has this never been done before in other applications (if there is 160 kW free for the taking) ??ringo wrote: I think around 160kW is free for the taking, but the dynamics of the turbine as said above puts a question mark there.
But it's more than 40hp i think.
You can look on the MGUH as an additional compressor, only that the loading is going to be instant and not progressive like compressing air. I feel the engineers will have to find a way to progressively meter how the MGUH sees demand from the MGUK and batteries. these load rates will have to be controlled so as not to shock the turbine.
170kW is what's left after the compressor takes it share. The MGUH may be able to take most of that in theory.xpensive wrote:Behave gentlemen, what's it gonna be, 50 or 170 kW from the MGU-H. bit of a difference there?
pgfpro wrote:Here's how I'm coming up with around 40 Hp recover after the compressor takes its amount.
Look at Borg Warner's Match Bot on plot 6 at 10500 rpm with the correct fuel limit entered.
Compressor Drive HP is 38.69 HP with a compressor efficiency of 76%. At this point the Calculated Percent Wastegating is 50.88% My simplistic mind tells me that it takes 38.69 HP to drive the compressor(exhaust going through the turbine). If 50.88% of the exhaust is being dump out the gate and you decided to use all of it and run it through the turbine then it would be another 38.69 HP???
http://www.turbodriven.com//performance ... rsin=92044&
