Stabilizer bar link breakage
mach11
mach11
Hi All,
Over the past couple of days, I have been getting failures on my front suspension stabilizer links (the links that connect the lower control arm to the stabilizer bars).
The links break off from the points where is it mounted to the stab bar. ( the pin section which is bolted to the stab bar with a nut).
Could any one suggest what might cause such a failure?
Regards,
"Be the change that you wish to see most in your world" -- Mahatma Gandhi
GSpeedR
GSpeedR
26
Re: Stabilizer bar link breakage
Kinematic binding.
mep
29
I think this cant be answered without some pictures.
marcush.
marcush.
159
two possibilities there :
too much load -peakload
or fatigue
reasons could be anything surely something has changed the peakloads .If you have not changed the car ,maybe time has ...a seized (because of rust) bar could put a lot of load into the aRB joints for example...
Without information it is impossible to pinpoint your problem .
Greg Locock
Greg Locock
237
Needs photos, but over articulation is the usual one if the designer sized everything correctly. What are you doing that is different?
KeithYoung
How many failures over those days?
I agree with the others we definitely need pictures. If the breakage happens very quickly, consider putting a GoPro there to record the break.
Naveed123
Naveed123
Could any one suggest what might cause such a failure? :mrgreen:
*** NAVEED ***
