Hi all,
i have been stuck thinking to that for a while, but still not found i good answer, so i hope you people from the forum can help me.
Does Anti effects (force based calculated or kinematically defined) affect longitudinal load transfer in any way?
I try to explain a bit better what i am after.
Let's say we have a car with a certain wheelbase, cg height (which we assume is not changing it's height when the car accelerates) and a double wishbone suspension both at front and rear axle.
Let's say we are accelerating and beacuse of this the car will see a load transfer from the front axle to the rear.
My understanding of the problem is that this Load Transfer will only be affected by the magnitude of longitudinal acceleration, cg Height and wheel base as:
LT = M x CGh x Long_acc / wb
The anti effect should only change how much of this load is reacted by the springs (so how much squat we have) and how much is going through suspension linkages.
Today anyway i found a paper from a "famous" race car guy stating that anti effects change load transfer magnitude. :O
What is your understanding of this problem?
As a side question, if we still assume that cg height doesn't change (which could well not be the case, but let's stick to that for now) how spring stiffness affects (if it does) the way load is transferred to the rear axle? It is "common knowledge" that softer springs should help in traction, but i don't see any reason (except from CG movement or road irregularities) they should influence load transfer or produce this.
Thanks!
