To answer thread's question:
Yes, they do sound right. They sound similar (or even better) to how engines in first turbo era have sounded
Sounds fine to me too. This is a better video where you can hear it going through gears :
It's not a constant sound, so it's not a recording.mep wrote:Sounds very artificial to me.
I wonder if it is a real recording or a generated sound.
It is just like the sounds in race simulations. I never really feel they match reality. Also there is that strange constant “flush noise”. I wonder where that is coming from. Maybe low sampling rate?
The turbo may land there, but for all intents and purposes that is a smokescreen. Just like the size of the 7th/8th gear (can't really tell how many they used but I believe I heard 7, which would mean they did use 8 since they didn't have a standing start) - they won't have the gearing pinned down until the engine spec is absolutely clear.xpensive wrote:First time I've seen the above image, can anyone xplain that strange looking turbo-layout, or is that just another smokescreen?
That striped section between the turbine and compressor housings cannot possibly be the MGU-H, can it?CBeck113 wrote:The turbo may land there, but for all intents and purposes that is a smokescreen.xpensive wrote:First time I've seen the above image, can anyone xplain that strange looking turbo-layout, or is that just another smokescreen?
In that design it clearly is. But the design may be schematic. The compressor and the turbine should be dual flooded and they are not. IMO the Merc final version can look very different to what we see now. But it is an entirely legitimate design to have the MGU between the two turbo machines. It has the added benefit that you can use one cooling system for the MGU and the shaft bearings. A hint that this is not the real thing is the lack of elements that could hold the bearings. Caterpillar btw. uses the same design. It sure minimises the shaft length. I have my doubts if the volume of the unit shown in this rendering is appropriate for the power the MGU is supposed to handle. It looks smallish to me.xpensive wrote:That striped section between the turbine and compressor housings cannot possibly be the MGU-H, can it?CBeck113 wrote:The turbo may land there, but for all intents and purposes that is a smokescreen.xpensive wrote:First time I've seen the above image, can anyone xplain that strange looking turbo-layout, or is that just another smokescreen?
Mercedes claims in the youtube comments it's real.mep wrote:Sounds very artificial to me.
I don’t think they are obliged to recover that amount of power from the exhaust. If they figure out that the rule is impractical they might go for a smaller unit. Let’s just estimate this 120kW from an engine which might have around 500kW does not sound to be realistic IMHO. I guess something like 5-10% of engine power would already be a lot.xpensive wrote:If that striped mid-section is supposed to be the MGU-H, which I seriously doubt is a realistic image, I find it hard to believe you can squeeze 120 kW from it?
I don’t really get what you try to say. So you say it is not a recording. So therefore it has to be at least edited or be a result of a simulation??xxChrisxx wrote: It's not a constant sound, so it's not a recording.
It doesn't sound 'hooverish' enough to be gas rush (where flow goes turbulent in the exhaust). So I'd put my money on turbo hiss becuase it seems to be worse when accelerating from low rpm. This makes some sense as they are running high boost pressures with relatively low mass flow, so they would be getting some marginal surge.
Doh... i meant to say its not a recording issue. Missed a bloody vital word out!I don’t really get what you try to say. So you say it is not a recording. So therefore it has to be at least edited or be a result of a simulation??xxChrisxx wrote: It's not a constant sound, so it's not a recording.
Then you don’t think it comes from gas rush but from turbo hiss?
I thought the sound of turbos is much higher in pitch where this flush sound reminds me more of airflow. Apart from that it might be some result of the special environment in on the dyno. Maybe exhaust gases flowing through a pipe out of the test section. Or just that the microphone quality is bad or not able to represent some of the sound.
Why should both the compressor and turbine be dual flooded?? They turbine surely should as the exhaust comes from two exhaust manifolds. But the compressor housing would only be "dual flooded" if there is two intercoolers. I don't think they will run two intercoolers. Of course they could but IMO they wont.WhiteBlue wrote: In that design it clearly is. But the design may be schematic. The compressor and the turbine should be dual flooded and they are not. IMO the Merc final version can look very different to what we see now. But it is an entirely legitimate design to have the MGU between the two turbo machines. It has the added benefit that you can use one cooling system for the MGU and the shaft bearings. A hint that this is not the real thing is the lack of elements that could hold the bearings. Caterpillar btw. uses the same design. It sure minimises the shaft length. I have my doubts if the volume of the unit shown in this rendering is appropriate for the power the MGU is supposed to handle. It looks smallish to me.
I don't see what is strange? And I'm a bit surprised that you of all people haven't seen that photo before Its very old. Came out just after Renault showed their engine renders which I believe is almost half a year agoxpensive wrote:First time I've seen the above image, can anyone xplain that strange looking turbo-layout, or is that just another smokescreen?
