![Image](http://s21.postimg.org/wo8r437af/2014merc_engine.jpg)
Note what appears to be a linear rpm increase at the final gear. The same is in all parts where it is used. This seems stange, as naturally the acceleration would decrease over time, so the shape should be curved somewhat.
Also, at 0:45 and 1:05 there strange "rev ups".
At the main straight I found a point where frequency reaches 371Hz so the revs are just below 15k.
As for "swoosh" sound, I listened in my Stax headphones and found basically two types of noises -- engine revving noise which changes pitch and constant background noise that doesn't change pitch and which sounds like air compressor. IMO the latter is cooling/ventilation. I do not hear turbine whistle or anything like.
The are some digitalness in the file, especially when it goes into top gears, which maybe from youtube compression (which is horrible) but may also be because of file manipulation. The linear rev increase puzzles me greatly.
