Often times the shapes used by F1 designers have nothing to do with what is ultimately most effective, but rather with what is best way to exploit what is permitted by rules.Hermax wrote:hello there.I need some help on this dihedral angle and how it affects the windflow.which one do you think is the best ?
This.flynfrog wrote:dihedral i is used to maintain stability on aircraft that need to bank to turn. It has no use on a car that only drives in a strait line. http://en.wikipedia.org/wiki/Dihedral_(aircraft)
Hermax wrote:Hello there.. i have a few questions regarding the aerodynamics and a few other related issues regarding the wings
before that,
let me give you a brief introduction about this challenge:
F1 in Schools is a multi-disciplinary challenge in which teams of students aged 9 to 19 deploy CAD/CAM software to collaborate, design, analyze, manufacture, test, and then race miniature gas powered balsa wood F1 cars.
The cars are powered by CO2 canisters, which are punctured to release the car at speeds of up to 60kmph. The objective of
the race is to tear down 20 meters in under a second.
1)questions regarding the aerofoil:
-what should the angle of the aerofoil be.....how much of a difference will it make?
2)should we have deflectors in front of the rear wheels?...if yes what purpose does it serve and how high should it be?
any help would be extremely appriciated!
will be looking forward for an asap reply
You need to take a few steps back. Before you can find an answer you need to define the problem.
What is the purpose of the competition.
What attributes of the car are best suited to this purpose. Looks like you started this but didn't finish.
When you have a question like what angle your wings should be at you should be able to look at your attribute list then decide what angle of wing best suites the attribute you are looking for. Also try doing a little research yourself before just posting questions. People here are more than willing to help but they are not going to do your homework for you.
you mean the design of this ?richard_leeds wrote:What's the context? Where is this on the bodywork?
got it !flynfrog wrote:dihedral i is used to maintain stability on aircraft that need to bank to turn. It has no use on a car that only drives in a strait line. http://en.wikipedia.org/wiki/Dihedral_(aircraft)
