That's not something the teams have control over.dren wrote:Could you just run always at +0.25% fuel flow?
Oh, the classic apple/banana comparison. How cleverly thought out and yet so inapplicable.timbo wrote:Oh, I remember a ban RedBull got for using flexible bodywork which is clearly against the rules.WhiteBlue wrote:Cheating the basic formula of a racing series is usually punished by a temporary ban of the competitor of at least one year.
Or do I?
Something can be banned only if it is detected. If teams use something which is within tolerances of the measuring equipment and it is left undetected it can't be banned unless the measuring procedure is altered.
PS time between upshifts at the first 3-4 gears is within 1-1,5 seconds.
Depends a bit on the nationality on the driver doesn't it, that's where the real apples and vettels are?WhiteBlue wrote: ...
A formula cheat in an air regulated formula is falsifying the cubic capacity or the boost or the rpm limit or the air box restrictor. Flexible wings definitely are not cheating the formula. They are a non compliance with the regulations which has to be evaluated for gravity.
Depends on how it works and how clever people are.WhiteBlue wrote:An accumulator cheat even if it is undetectable by the measuring equipment - which it isn't in my opinion - is per se illegal and will be heavily punished on detection. Detection is always possible if the engineers of the perpetrating team become whistle blowers.
Surely cheating is only detected if it can be measured? The flexi wing wasn't detected because it couldn't be measured.WhiteBlue wrote:A formula cheat in an air regulated formula is falsifying the cubic capacity or the boost or the rpm limit or the air box restrictor. Flexible wings definitely are not cheating the formula. They are a non compliance with the regulations which has to be evaluated for gravity.
Which is to flow all fuel through the FIA supplied meter, which will have been calibrated.richard_leeds wrote:So just like the teams designed flexi wings to meet the test criteria, the teams will design fuel system to meet the metering criteria.
Nope the idea is to get the right amount of fuel at the right time.wuzak wrote:Which is to flow all fuel through the FIA supplied meter, which will have been calibrated.
So to get more flow requires either a) modifying the flow meter - which is a big no-no or b) installing another fuel line - which would be obviously illegal.
But are they at the injectors? I thought they're not. That would be quite a contraption to fit a meter right before injector.richard_leeds wrote:Unfortunately homolgated sensors at the injectors will exclude gains from tuned pipework.
Can be. If they take only a few measurements in a second there's plenty of room for maneuver, there would be around 90 firings at each cylinder if I didn't mess my math, and a second is a time spent between upshifts.richard_leeds wrote:There might be something to exploit in the sampling rate and averaging of the data? For example changing gear would create a dip in fuel use for a fraction of second which might be compensated by a burst of extra fuel in the next fraction.
I bet the homolgation specifies the max pipe distance to the injector. Also the injector has to be from an approved list, so it'll be no surprise that pipe is also specified as part of the injector spec.timbo wrote:But are they at the injectors? I thought they're not. That would be quite a contraption to fit a meter right before injector.richard_leeds wrote:Unfortunately homolgated sensors at the injectors will exclude gains from tuned pipework.
They directly measure the pressure, temperature and flow supplied to the injectors, but this could be immediately after the in tank sensor just outside of the fuel tank, right? I don't see specifics for location. Thinking it's in a different spec?2014 Regulations wrote:5.10.4 Homologated sensors must be fitted which directly measure the pressure, the temperature and the flow of the fuel supplied to the injectors, these signals must be supplied to the FIA data logger.
5.10.5 Only one homologated FIA fuel flow sensor may be fitted to the car which must be placed wholly within the fuel tank.
5.10.6 Any device, system or procedure the purpose and/or effect of which is to increase the flow rate after the measurement point is prohibited.
This may be too simplistic, but surely engine manufacturers who are trying to get customer teams have to reveal their engines spec to entice them to sign up to their engine? You wouldn't expect any team to sign on the dotted line without having solid information to base their decision on. These deals are worth millions and will hugely influence the teams performance moving forwards. The more people know, the more likely that rumors and information are going to be spread. How many people work at Merc HPE for example who might know the numbers? I'm sure that as we get closer to 2014 more and more is going to leak out. i find the 100hp hard to believe as well but I doubt that these rumors have just appeared out of thin air.richard_leeds wrote:I bet the homolgation specifies the max pipe distance to the injector. Also the injector has to be from an approved list, so it'll be no surprise that pipe is also specified as part of the injector spec.timbo wrote:But are they at the injectors? I thought they're not. That would be quite a contraption to fit a meter right before injector.richard_leeds wrote:Unfortunately homolgated sensors at the injectors will exclude gains from tuned pipework.
I also imagine the teams can only use the sensors in a batch (like the tyres) so no chance to pick out the sensors at the upper end of the calibration.
Anyway, eve if all our regulation wriggling was possible, I still can't see how it eeks out an extra 100bhp. Neither can I see how teams know the hp for each engine supplier. It'll be like Red Bull seeming to be in the pack in winter testing, same in FP1 & FP2 in Australia, pick up a bit of pace in FP3 , but then storm to pole in Q3.
I agree. 100hp seems too much. Surely that's a combined ERS+Engine figure?richard_leeds wrote:Anyway, eve if all our regulation wriggling was possible, I still can't see how it eeks out an extra 100bhp.
