Hey, I'm a newbie here. I just want to know how the track's altitude plays into it's challenge. I also would like to know the altitude of a few of the highest tracks.
Thanks
Are you sure 20% is right ? From the Interlagos altitude I’ve found, also assuming Silverstone is at sea level the pressure drop should be in the order of 8-9%, to have a 20% density drop you should have a difference of 10% in the absolute temp meaning for example 15°C in Silverstone and 41°C in Interlagos. Can you post the data you used for the calculation ?Enzo wrote: If we compare the Silverstone and Interlagos in terms of temparature and altituse then we will come uo with a 20% drop of air density [...]Power and drag will also drop by 20%, so max speed remains the same
You are right that it would be very easy for people out to calcuoate the power loss due to density fall if density drop would mean exactly the same drop of power. That's why i wrote that all these are only in theory but theory is not so far from practise.Reca wrote:....the reduced density influences also a few other engine parameters, so the power lost is a bit higher in %, and as a consequence the top speed, also assuming the aero trim is the same (it really is in Interlagos and Silverstone ?), results a bit lower anyway. It was a further addition to explain why, as I said in my previous post, statistical data or simulations are used to calculate the power lost (otherwise it would be quite easy, don’t you think ?)
my point was exactly that to have 20% of difference in density you need a big difference in temp. I don’t wanted to say that 20% is impossible, only that it was unlikely considering the period the two GP are planned.Reca wrote: the pressure drop should be in the order of 8-9%, to have a 20% density drop you should have a difference of 10% in the absolute temp meaning for example 15°C in Silverstone and 41°C in Interlagos
You were “lucky” with weather then, and you don’t need to look at UK, here we had snow also in March. I remember that one of these cold days I’ve seen a few trucks carrying Supersport bikes to the track, I don’t think that test was really meaningful. Point remains that Silverstone GP is in July, not in MarchEnzo wrote: Here in Greece we had in March a temparature of 10-15 i expect to see temps in UK during March well less than 10 'C
