I read this far and I'm stopping here. Why? Because this is most likely the system in use. It is most likely not any of the other crazy ideas floating around. We'll know eventually.Tim.Wright wrote:Probably a hydraulic accumulator and/or valving unit for the interconnection of the left and right suspensions. Might even be connected to the front suspension too but its not so clear in that picture.
None of this is new technology. It similar to the old Kinetic (now owned by Tenneco I believe) suspension system. Below you will see two accumulators in such a system. What they are doing would be something similar, but the exact plumbing is impossible to know really.
http://www.caroto.gr/static/media/2011/ ... -bar-3.jpg
This system can be implemented across traditional dampers or not, it doesn't matter. The system as shown only decouples roll but by interconnecting the heave dampers (actuators) you get the same concept in pitch. The accumulators may be interconnected and more complicated so as to give you some tuning of roll rates, pitch rates, and roll moment distribution. That's where the clever part comes in to tune the inherent issues from running this set up.
Note the system ONLY gives accumulator driven stiffness in pure pitch and roll. The heave stiffness and warp stiffness from the system are ZERO. So you still need heave springs, wheel springs, etc. to define those modes, but they can now be decoupled from pitch and roll.
I'd guess heave spring is same as always, tuned to set height at downforce levels. Single wheel rates (and warp rates) are now lower giving enhanced mechanical grip and feel, but there is no compromise in the pitch and roll rates because of this. Those rates are set very high with slight negative feedback control from opposite wheels and thus aerodynamic attitude is overall improved.
Just my quick guess. Simple really.
One extra thing to note. The system will work on traditional dampers, but the pistons need to be solid or very stiffly valved in order to drive fluid to a partnered corner's chamber and not allow much to pass across its own main piston. Basically the damper's normal valving needs to be moved somewhere in the desired fluid path and removed from its traditional location on the piston. This could be done in a manifold that also holds the accumulator circuitry. Think about it.
