I'm asking because I have this ridiculous idea of making a carbon fibre chassis myself but I'm not sure it would actually be strong enough with hand lay-up.
![Razz :P](./images/smilies/icon_razz.gif)
I have been researching into this subject for quite a while but I can't figure it out.
I think a wet layup would be practical. Getting vacuum infusion down and getting the equipment would likely be MORE impractical due to the expertise and cost associated with it. A wet layup is quite easy.Jersey Tom wrote:Why wouldn't it be strong enough with a hand lay up? I don't think it would be practical doing something that size in a wet layup, with that many layers of carbon and core and all.
The better way to do it, which would be tricky to set up but do-able, would be vacuum resin infusion.
I would agree its definately a ridiculous idea. I'd basically say.. don't do it.
What are the expected roll moments of the vehicle? How rigid does the chassis need to be in order to maintain suspension sensitivity? A good steel spaceframe can probably be done to 1500-2000 ft-lb/deg.
How would you do the design and analysis? What software do you have available that's capable of composite analysis with multiple layers of directional plies all over the place?
How would you make the tooling? If you were to have it machined out of tooling board (the right way of doing it IMO), expect to pay $10-15k. If you were to do it by hand expect to spend a month or two.
Carbon has been in short supply for the past couple years. It could be very hard to come by large quantities of carbon without a D-pass.
If doing vacuum resin infusion, expect to do a couple trial runs first with fiberglass to make it work right.
