Tommy Cookers wrote:raymondu999 wrote:How exactly does KERS help with traction? Honest question. Are you suggesting that they're reversing the KERS motor direction to hold back the forwards torque?
as I said, the inherent characteristic of the KERS machine amounts to substantial opposition to wheelspin or locking
so it does some of what TC and ABS would do
eg for KERS motor action eg between 9000 and 18000 rpm the applied voltage would be swept proportional to rpm at all times
eg (say) 95 Volts at 9000 and 185 V at 18000 rpm, and have rather constant EM torque (or torque proportional to ICE torque)
the EM torque being proportional for all rpm to the 5 V margin of applied voltage over the back emf that is proportional to rpm
if there was wheelspin eg suddenly raising rpm to 9500 the EM torque would fall to zero
wheelspin to 10000rpm would automatically cause negative EM torque (ie generating and storing electrical energy)
a totally standard feature of any motor drive is inbuilt adjustable limiting of the sweep rate ('slew rate'), for many practical reasons
our slew rate would be set around maximum acceleration without wheelspin, this would be mapped
the KERS machine 'knows' its own rpm and even rotational position anyway
so no wheel speed sensor is involved, so it's not TC
this basic characteristic in 'generating mode', tends to oppose rear wheel locking, lowering KERS torque as wheels suddenly slow
internally to the motor and drive, other advantageous behaviour could be arranged without breaching any rules
a few races ago didn't we see footage of Mr Webber's car and Caterhams ? leaving tyre chatter marks ?
it has been said that RB use less KERS power (peak) than allowed, isn't this consistent with low-level KERSing in corners ?
