Ferrari F138
Gerhard Berger
Gerhard Berger
-1
Re: Ferrari F138
diffuser wrote:
Tim.Wright wrote:
l4mbch0ps wrote:As far as the great starts go, I suspect this is due to the dual rate rear roll bar.
http://scarbsf1.com/blog1/2011/06/10/fe ... -roll-bar/
Article from 2011.
Anti rollbar has no influence on the starts. The start quality will be due to something in either the driver, engine torque management or clutch release management.
agreed it does have some to do with getting power to the ground in corners or atleast reducing roll....
Looking at this picture http://i.imgur.com/4Po0Qik.jpg from monza 2013... It looks like a pullrod rear suspension.
I don't think they run the pushrod rear anymore.
Yes the article is from June 2011 (i.e. it is about the F150 Italia, and that is the version of the car before the suspension geometry was revised at Silverstone that year.
Re: Ferrari F138
Japan 2013 - Thursday (10.10.2013)
via AMuS
f1316
f1316
82
Re: Ferrari F138
Lots of flo vis on the bear - must be a 2014 part
CBeck113
CBeck113
51
Re: Ferrari F138
They want to know when he farts...
bhall
bhall
244
Re: Ferrari F138
That it appears to be functioning leads me to believe it is, in fact, not a Ferrari design.
Holm86
247
Re: Ferrari F138
When i first saw the picture i thought it was greenpeace again :) They have broken in at different Shell refineries dressed as polarbears :)
Perhaps it's just Ferrari's way of mocking them?? By painting a polarbear in illuminescent paint :D
radosav
radosav
Re: Ferrari F138
Maybe it is Kimi ?
Re: Ferrari F138
turbof1 wrote:
diffuser wrote:I think Ferrari has been a mess in the last 2 years, all stemming from aero issues. I think the aero team has been a major disappointment. I agree with Alonzo it is a miracle that they are where they are in points. The best thing to have happened this year was the switch to the Lotus aero guy in late September.
Well that and the addition of James Allison.
They haven't been such a mess. Just take a look at those 2 years and Imagine Red Bull Racing never existed; you'll inmediately get a different picture. Ferrari actually did a very good job, but it's just that red bull whipes the floor with everybody else in F1.
Ok maybe "a mess" Is too strong. On race day things are a bit different (speed balances out between teams when carrying 150kg of Fuel). If you're of the mind that Qualifying is a good representation of the cars actual pace... Then the Ferrari has been weak on Qualifying and the true pace of the car is much slower than the points it racks up on race day. The points you bring home on Race day is influenced by how well the other drivers are doing. Lets face it, last year Schumi just about had 1 DNF in 2 races either cause he ran into someone or his car broke down. I can think of a couple of races last year that Hamilton took himself out of the race cause he just pushed too hard and button was lost for a good part of last year. Add to that Alonzo was just about perfect last year and still overachieving this year.....It can lead to an incorrect vision of the car.
Lets face it, the car has been 3 or 4th fastest in the last 3 years.Worse, on average, they've been about .750 seconds off the pace.
f1316
f1316
82
Re: Ferrari F138
And what's more concerning is that, whilst they were slow in getting off the ground with the new regulations in 2009, they were actually very competitive in 2010 and close in pure pace terms to the RBs. Albeit they were reasonably competitive at the start of this year, as a general rule they 've slipped further back ever since.
Then again, a lot of their problems have come from wind tunnel correlation and/or (in)ability to get the same results from exhaust technology as other teams. With that in mind a) the tunnel will hopefully be much improved from this month on b) I personally don't see how teams can get round the new exhaust placement to get much benefit (which I'm aware is a conversation for somewhere else), so Ferrari may have the opportunity to play to their strengths a little more from 2014.
For now, the F138 is a blighted by its slow corner speed; I think they will actually do better in Japan than in recent races, due to the nature of the track, as they were fast in quick corners for the past two years.
tpe
tpe
-4
Re: Ferrari F138
The last time when a Ferrari car had good traction was 2004. After that year they never had a car with good traction. Even at 2007. So after the big changes of 2005, Ferrari had traction problems.
Re: Ferrari F138
Japan 2013 - Friday (11.10.2013)
emmepi27
emmepi27
141
Re: Ferrari F138
Longer exhaust for Massa, shorter for Alonso (see image posted by Stefan)
csponton
csponton
Re: Ferrari F138
Longer exhaust for Massa annd rake greater than Alonso (shorter exhaust)
Re: Ferrari F138
I think they run equal rake.
So they introduced the longer exhaust in Spain. Now we are nearing the end of the season and they still don't have a clue which one is better.
Ferrari should stop wasting times on solution which are redundant for next year. They should be focussing on testing 2014 parts.
f1316
f1316
82
Re: Ferrari F138
turbof1 wrote:I think they run equal rake.
I think 2nd in the constructors' is still quite important to them and, without a more stable rear, they're not really looking fast enough to keep it. So I think they still think there's time to be found by having a better exhaust solution.
However, you are right, why it's taken them this long to incorporate something which their data obviously showed was faster is a bit ridiculous.
