SectorOne wrote:Popular belief suggests that the Renault engine is the weakest but the most fuel efficient and the most "usable" or map-friendly.
But with Renault being able to "upgrade" their engine a while back, is it possible that they now have horsepower on par with Mercedes (who are believed to have the strongest engine) while still retaining the other good things the engine did well prior to that?
What were they allowed to change during this upgrade?
I'd like to take the most recent change as an example: Ferrari changed their engine spec back in Spain 2010. They effectively were allowed to do so on ground of reliability reasons. Scarbs wrote a very interesting and detailed report about that:
http://scarbsf1.com/blog1/2010/05/12/fe ... ification/
I like to quote this specific piece:
Teams are however allowed to make changes to the their engines for reliability reasons, this applies both to resolving issues that have ‘blown up’ engines, as well as impending failures. To request a change, teams have to apply to the FIA outlining the reason for the change and the resulting changes. This information is passed around the other engine suppliers, this transparency helps to reduce excessive changes and reassures teams what their rivals might or might not be getting up to.
So whatever advantage Renault got out of their engine spec change, other teams were informed about it and accepted it.
I also would like to mention James Allen's article about engine performance in general in 2009, who was brave enough to put numbers on it:
http://www.jamesallenonf1.com/2009/11/a ... e-in-2009/
The Renault won out this year [2009] on fuel efficiency, however, which was pretty important this year and will be much more important next year [2010] with no refuellling. Compared to the Mercedes, the Renault would go four laps longer on a full tank of fuel, which is worth about 3/10ths of a second per lap next year. The Ferrari was less efficient than the Mercedes, as we saw on several occasions this year.
Most teams reached the conclusion, based on acoustic analysis and GPS, that the spread of engine power from the best to the worst engines was less than 2.5% this year. This means that, if the Mercedes is believed to have had 755hp, the least powerful engine was 18hp down, which is worth just under 3/10ths of a second per lap.
