You should visit your local doctor for an ear check then Clearly the difference is that Vettel's car sound a bit like Barrichellos when coasting, but when accelerating the sound is huuuuuuuuuuugely different.Hail22 wrote:Rubens Barrichello / Vettel:
http://www.youtube.com/watch?v=7_SAL6mkQMw
I wouldn't mind picking the brains of the more senior members of what they think between the two videos side by side?
Personally for me I cannot draw much difference between the two, but I may/may not be wrong.
Cheers in advance.
They used to and it was silly; q3 has been much more exciting ever since that rule was binned.Glyn wrote:I have always wondered why cars don't qualify with race fuel. :/
I don't think so. Ideally TC would measure the wheel speeds at each wheel and compensate timing or throttle position to avoid exceeding ideal slip. Since that is illegal, and there is a spec ECU, I don't think your idea would work because you'd have a closed-loop system which would violate the FIA rules.turbineBill wrote:Since the available traction is dependent upon exaust emission, car-speed, wind-speed, side-ways g-force, wheel-load, etc (and diffuser pressure ?). It would make sense to feed all these parameters into the throttle demand map. Is this legal ?
No, because nothing like this number of such inputs is allowed (only one is)turbineBill wrote:Since the available traction is dependent upon exaust emission, car-speed, wind-speed, side-ways g-force, wheel-load, etc (and diffuser pressure ?).
It would make sense to feed all these parameters into the throttle demand map. .......
Is this legal ?
