astracrazy wrote:so i don't get what your gaining?
if your having your under body slopping (in fact it works out slightly level) from BB to AA then why the need for sudden drop on top of the tub? the top may as well tailor down from bb to aa
with your design and with a standard design your lowest point at bb @ 625 is 225mm and aa @ 525 is 250 so the volume under the tub is the same
if i have totally miss understood then i apologise, but the only way i can see with your design to increase volume would be to have the 100mm change underneath as well, but i don't think that would work too well
Hmm, perhaps I'm not being very clear.
At B-B, it must be 625mm maximum height. At A-A it must be 525mm. The chassis has to be of a certain cross sectional area. Therefore if the top of A-A sweeps down towards B-B at a gentle slope then the underside must also do the same at virtually the same gradient as it has to meet the cross sectional area requirements.
By keeping the chassis at 625mm for as long as possible, the underside of the chassis can also remain high as the area requirements can be met this way. The step down to A-A on the top side is therefore necessary to allow this keep the chassis high and still be within the regulations.
Regarding the potential step beneath the chassis: The bottom of the chassis can be sloped (albeit at a bit steeper angle) to conform with the cross section regulations rather than a huge step like the top. However the advantage with this design is that the underside can still remain higher than that of a chassis that is sloping right from B-B to A-A, but only marginally.
It is difficult to explain but it is quite simple. At the end of the day it is up to the teams to decide if it is worth having a tiny bit extra volume beneath the car to play with or go with a more convential design that maximises CoG.
Apologies if I'm still unclear!
