Most peculiar suspensions.
xpensive
xpensive
214
As a follow-up on another thread, which suspensions were the most intriguing and/or different ever?
Ferrari 312 B2;
Sombrero
Sombrero
126
Re: Most peculiar suspensions.
Hesketh 308 : Postlethwaite was looking for a way of fitting simple, lightweight progressive springing to the car and latched onto the idea of using rubber springs after a friend involved in designing rubber damping for buildings in earthquake zones suggested the idea. Early tests in 1974 proved unsuccessful until a special non-creep rubber was developed by the Malaysian Rubber Producers Association. This was formed into springs by the Aeon Products company and following more productive testing results, fitted to the car from the 1975 Argentine GP.
marcush.
marcush.
159
nick wirths simtek prototype:
as i remember the plan was to have the suspension mounted on the horizontal outriggers by means of rotating bars tubes very much like a VW Beetle front suspension?
marcush.
marcush.
159
Ferrari experimented in the 70s (1975 and 76) with deDion rearaxles ,it seems not many pictures have made it in the web....
Ferrari 312T -one of the motivations for the Transaxle gearbox was the packaging of the DeDion axle -at least thats what Lauda said back then...never raced if I´m correct?
Sombrero
Sombrero
126
Ferrari 312 T 2 1976 De Dion - I saw also a video from a testing at Fiorano with Niki Lauda but I was not able to find it again... I guess also it never raced in official GP.
The Alpine A350 never made it to the track because of its engine but the suspension was intriging.
Designed by Richard Bouleau, known sometime as "flat" suspension.
Its perfect on smooth roads.
http://irsforum.boardhost.com/viewtopic.php?id=485
Tires remain vertical during braking or launching as both tire move up at the same time.
Also no dangerous rear wheel positive camber when braking.
During corners BOTH wheels uppers turn to the inside of the corner.
Thus getting beneficial camber thrust from both inside and outside tires.
i.e. negative camber for the outside tire and positive camber for the inside tire.
Thus perfect so far.
The only drawback is on bumps.
Both wheels change camber, with an even more pronounced angle than a solid axle.
Lycoming
Lycoming
106
This one sure caused a stir when it first emerged. While giving the event organizers pause as to whether or not your system is legal isn't desirable for the team building the car, it pretty much guarantees that whatever they made is at least interesting...
scarbs
scarbs
393
what about the Michelin - Renault OPT suspension..?
http://scarbsf1.com/renault_opt/Renault_OPT.htm
Tim.Wright
330
I suppose that got shot down with these stupid rules which govern how many attachment points to the hub which basically mandate a double wishbone suspension?
scarbs
scarbs
393
IIRC its was more a chnage to Art10.2 on suspension geometry changing when on the move, than the multiple attachment points.
Tim.Wright
330
Seems like they've kept a good lid on innovation for a while then. Maybe I'm just bitter because I'm a suspension nerd.
To avoid the risk of triggering a rant, here is the lotus active ride system being controlled by someone blowing into a pitot tube
[youtube]http://www.youtube.com/watch?v=xjHNS8Jvz78[/youtube]
Ciro Pabón
106
Renault 2006 tuned damper (hi, scarbs!)
Ciro
Ciro Pabón
106
Lotus and Mercedes FRIC, 2013
Ciro
Ciro Pabón
106
Red Bull banned ride height sensor, 2013, bullet (4)
Ciro
Ciro Pabón
106
Tyrrell, 1976
Ciro
Ciro Pabón
106
Williams active controlled dynamics, 1991-1992. You have to watch this video: eerie
[youtube]http://www.youtube.com/watch?v=sjbc1tmKi6g[/youtube]
Ciro
