Blaze1 wrote:...mentions in Autosprint that the 2014 cars will have higher top speeds, which did surprise me. I wonder if this is due to PDRSs, reduced downforce as a product of the technical regulations or perhaps a combination of both?
I think this could be simply a case of a desire to lower the drag of the overall package to make up for the fuel flow restrictions. Apparently we shouldn't be expecting a really big HP hit so it follows that same power with less drag = higher top speed. The downforce limits are always theoretical, and teams will always find tweaks to get a wee bit more, but in their efforts to do so they can't afford the drag penalty of the 900HP days and expect to both stay on pace and not run out of fuel. I think this is where Mercedes may have the edge, in this go around. I suspect the reason Merc showed such pace last year was due to slightly lower cd. It's conjecture on my part, but i think if you look at the W04 from that angle and then the rest of the field i think you'll agree. So in that sense, i expect that they won't be left behind on the straights next year but as much as people suggest the contrary, i think it will be an engine year, because the power unit is more complex, the optimum usage of it is going to be decisive in deciding who's competitive. Similar to the tyre wars years in that sense. And i think the advantage there is pretty up in the air.
Mr Evans talking about a 30% higher efficiency target at one point:
http://www.youtube.com/watch?feature=pl ... qiiuFv7HcY my math was a lot more conservative.
