turbof1 wrote:Maybe I didn´t express it correctly, I was showing two scenarios: 1: they improve the drag, so the top speed is increased. 2: They improve the downforce but don´t increase the drag, so the cornering speed will be faster and the top speed will increase too.
If you consider any downforce improvement also increases the drag, then it will depend on the ammount or ratio between both of them, so you can´t say for sure what will happen in that case...
Any downforce improvement always comes with drag. Just adding downforce will limit top speed and acceleration due the extra. You can improve it by substituting low L/D element by improvements in higher L/D areas. However, in practice this is very difficult. Teams ussually prefer to have more downforce then less drag.
They usually prefer it, but that does not mean drag improvement does not exist. Even when downforce improvements are more usual, drag improvements does already exist
turbof1 wrote:Any downforce improvement will improve cornering speed. However, running more downforce means a lower top speed, in which case you'll want to adjust your ratio's, and vice versa. To simplify: you have a top speed limit imposed by the drag, and a top speed limit by the ratio's (hitting rev limiter). You want to match those for optimum acceleration and speed. Concerning top speed there is no benefit shedding drag while you are hitting the limiter.
You´re missing the main point here, next seasson they will only hit the limiter in Monza, so your reasoning does not apply.
For the whole seasson except Monza, the cars will race with too long gear ratios, so the the speed limit will
always be imposed by the drag, wich is the main reason I said DRS will be much more effective next seasson so overtaking will be a lot easier. Today they hit the top speed limit imposed by the drag with DRS closed, but when they open DRS then they hit the top speed limit imposed by the limiter. Next seasson that will never happen, only in Monza, so anytime they open DRS, the top speed difference between cars with DRS open or closed will be a lot higher than today
That´s also the reason I said next seasson they could use ERS to improve top speed, and not only to improve acceleration like they use it today, because drag will be the most limiting factor, so when they´re hitting the top speed limit imposed by the drag, if they hit the ERS button, the top speed will increase
