Also wings are less likely to stall on the high pressure side.
remember this car?
there wasn't any issues with the upper element being stalled.
My intention is simply to put an airfoil shaped scope a bit lower that shoots a jet stream outwards.
To get more air underneath the car.wesley123 wrote:I don't see why you would want to turn the end plates in board again
The first FW is nothing more then cut 'n past from the 2008 ferrari.jaba.hut wrote:Goran who is member of this forum asked me if I could post in his behalf images and link to blog he ran into with two solutions applied to next Ferrari car of front wing.
Altough for the first I am pretty sure is not legal because top element cannot connect to nose cone. But main idea is inwash solution as now wing is narrower so maybe this could return as way to direct air around front wheels. There is also other wing with simulation of air stream around front wheels.
http://erteclas.wordpress.com/2014/01/0 ... os-de-ala/
Wing 1
http://erteclas.files.wordpress.com/201 ... =640&h=360
Wing 2
The only benefit I could conceive is to push more air towards the inlet of the sidepods in order to slightly improve cooling and keep the sidepod inlets ever so slightly smaller.wesley123 wrote: So no, I do not see any reason why to return to inboard end plates
I think it was a bit more complicated that that - for example mclaren and redbull before 2008 sacrificed a big chucnk of the front wing surface (all the of wing in front of the front wheels) in order to have a better inwash solution (less curved endplate). Ferrari were less aggressive in that.turbof1 wrote:Back then they couldn't sacrifice FW surface for agressively bended endplates;
Yes, of course I simplified a bit the truth - mclaren used a bit less surface, but in response had more elements and a higher AoA, which created roughly the same front DF for more drag, but the bigger endplates diverted air better away from the tyres, which in turn created less drag. It's more a difference in philosophy that played the differences between the 2.shelly wrote:I think it was a bit more complicated that that - for example mclaren and redbull before 2008 sacrificed a big chucnk of the front wing surface (all the of wing in front of the front wheels) in order to have a better inwash solution (less curved endplate). Ferrari were less aggressive in that.turbof1 wrote:Back then they couldn't sacrifice FW surface for agressively bended endplates;
Yep. Interesting he uses that terminology to speak of vortices, but there's no denying that's what he's referring to. I think it's pretty evident teams will indeed continue sending air OB of the tyres. As Anderson says the key will be getting both flows go merge as soon as possible. Voids behind the wheels accounting for more than 1/3 of the cars overall drag level is quite important. Will be interesting to see the solutions each team come up with.shelly wrote:Note how many times Andrew Green repeats the word "structures" - meaning vortices.
