Is turbo lag purely a issue of boost or a byproduct of a small capacity engine running in at low RPM?WhiteBlue wrote:
It is indeed expected that Turbo lag will not be an issue due to electric spool up assist by the MGU-H.
Its a turbo issue. With many factors. Turbo engines will always have lag. Its just a question of how much. Unless they are assisted with an electric motor as the 2014 F1 engines.WilliamsF1 wrote:Is turbo lag purely a issue of boost or a byproduct of a small capacity engine running in at low RPM?WhiteBlue wrote:
No fuel injectors are permitted in the exhaust. Without VVT, there isn't a way to delay the exhaust closing to boost turbo performance, although you could fire spark late in the cycle. But again, all this is moot because the MGU-H is going to constantly be spinning the turbo.PABLOEING wrote:¿It's`possible a bang-bang antilag rally system in the F1 2014 engines?
The exhaust gets hot enough to ignite the fuel. So just cut the ignition and the fuel will burn in the exhaust.tuj wrote:No fuel injectors are permitted in the exhaust. Without VVT, there isn't a way to delay the exhaust closing to boost turbo performance, although you could fire spark late in the cycle. But again, all this is moot because the MGU-H is going to constantly be spinning the turbo.PABLOEING wrote:¿It's`possible a bang-bang antilag rally system in the F1 2014 engines?
tuj wrote:turbo lag is the effect of the fact that the turbo is a feedback machine: it needs strong exhaust pulses to pressurize the cold size of the turbine, which then pressurizes the intake, which then makes more power, resulting in stronger exhaust pulses, which then hit the hot side of the turbine. So a turbine is generally sized appropriate both to the engine size (displacement) and to the intended rev running range. Put a big turbo on a small engine and that creates a lot of lag. Put a small turbo on a big engine and there is virtually no lag.
But with the 2014 cars, the turbo will always be spooled up due to the ERS system.
Engine coolant temperature has been said to be around 130°C at radiator entrance.dren wrote:Anyone have an idea of typical SI intake temperatures and typical engine coolant temps?
Crucial_Xtreme wrote:Renault Chooses Bosch Injectors like Mercedes It seems Ferrari will be the only team to use Magneti Marelli injectors. The article says MM injectors are already injecting fuel at 500 bar while Bosch is still working to get to said limit.
Motor-Generator-Unit, the motor part means it can drive the turbo as well so there need not be any lag, the turbine can be spooled up with electricityPavan_MP423 wrote:tuj wrote:turbo lag is the effect of the fact that the turbo is a feedback machine: it needs strong exhaust pulses to pressurize the cold size of the turbine, which then pressurizes the intake, which then makes more power, resulting in stronger exhaust pulses, which then hit the hot side of the turbine. So a turbine is generally sized appropriate both to the engine size (displacement) and to the intended rev running range. Put a big turbo on a small engine and that creates a lot of lag. Put a small turbo on a big engine and there is virtually no lag.
Exactly!! But MGU-H absorbs power from turbine shaft, recovering energy from exhaust. So unless the turbines are driven by exhaust carrying sufficient energy there will be lag.
How about we put this into perspective? Two cases:
1. During Race start: The moment before drivers launch their car, can we assume that exhaust pulses are intense enough to energise ERS(MGU-H only), and in turn have the turbines spooling? This prevents turbo-lag.
2. Exit out of the slow corner: We know that as the cars enter & exit outta slow speed corners, the engine RPM will be low for a small span ( at least until 30% throttle ). So the lag continues to exist.
Crucial_Xtreme wrote:As of now it seems Ferrari will be the only power unit to use Magneti Marelli fuel injectors. It seems other teams have chosen to go with Bosch. Teams have a choice between one or the other. Rumors in the paddock are that Magneti Marelli are already injecting fuel at 500 bar while Bosch is working to get to this limit. Teams must decide on the injectors by Feb 28th.
via OmniCorse.it
hardingfv32 wrote:May I assume that the pump is a 'single piston mechanically operated by a multi-lobe (2, 3 and 4 lobes) cam' discussed on Magneti Marelli web site? Where would this be commonly mounted the engine?
Brian
I m wondering about that racing high pressure pumps! Are they also use air spring in it or are is spring hysteresis irrelevant for DI (pressure +/- build up, precision etc.) ? If i m right mechanical steel springs (before invention of pneumatic accutation manufactures try lightweight titanium also) REVs up to 12 kRPM so it is very on the limit? So how they deal with that?scarbs wrote:The GDI pumps are mounted on the cylinder heads and cam operated as you say. You can see the pumps on the inlet cam of the Renault 2014 engine.
I'm surprised the Bosch pump isnt up to 500 as their wbsite list a stock part with the throughput
http://www.bosch-motorsport.de/en-US/li ... 336971.pdf
No, you are not correct on two points. The MGU-H is a bi dictional electric machine. It draws power from the Energy Storage (ES). So we expect the turbine to be electrically spool assisted in all critical conditions when exhaust blow down is insufficient to provide the desired boost. In other words: Lag will be prevented at all times.Pavan_MP423 wrote:... But MGU-H absorbs power from turbine shaft, recovering energy from exhaust. So unless the turbines are driven by exhaust carrying sufficient energy there will be lag.
