2014 Design
Re: 2014 Design
Similar to the Hungary spec of the R30 RW?
Holm86
247
Re: 2014 Design
Blackout wrote:Similar to the Hungary spec of the R30 RW?
http://img801.imageshack.us/img801/2048/rwbelgium2f.jpg
Precisely :-) Would it be possible within 2014 regs??
OrangeArrows
OrangeArrows
Re: 2014 Design
Is it allowed in 2014 to strech the bodywork for more rear downforce? Just like this http://www.autoguide.com/auto-news/wp-c ... 12x408.jpg
OrangeArrows
OrangeArrows
Re: 2014 Design
Is it allowed to strech the bodywork to the rear wing for more rear downforce>Just like this http://www.autoguide.com/auto-news/wp-c ... 12x408.jpg
shelly
shelly
136
Re: 2014 Design
If you run a small delta extension in the central 150mm you could use the two vortices for downforce like strakes
twitter: @armchair_aero
Re: 2014 Design
shelly wrote:If you run a small delta extension in the central 150mm you could use the two vortices for downforce like strakes
*central 200mm. It got extended.
shelly
shelly
136
Re: 2014 Design
I was looking at this image from @thewptformula on twitter;
representing 2011 mclaren swnowplough. I think it is a viable variation of the "bulbous bow" type - you'd have a protruding flat instead of a protruding bulb. Proven aerodynamic concept, but I am not sure it complies with the rules.
Maybe some cars will have a low wide and flat nose (like 2013 ferrari 340mm lower), with a convex tapered dome above it. have not seen any sketch of this type of nose around, it would look like a mp 4-22 nose (or the grey example above) with wide chimes at the bottom
230
Re: 2014 Design
Borealis wrote:The Ferrari one may be legal if the bow nose forms a single section with the upper nose. Two nose supports are allowed to support the front wing as far as I'm aware. Is there a rule dictating the mounting points of the wing supports? If not could this be a legitimate get around? (as already suggested by Gary Anderson).
ferrari design is not legal. No body work should be above a diagonal line that goes from 650mm from section AA to 300mm 50mm behind the furthest point.
Which is saying that the nose must slant downwards regardless of the design.
Holm86
247
Re: 2014 Design
shelly wrote:I was looking at this image from @thewptformula on twitter;
https://pbs.twimg.com/media/BeDXWXrCUAA5mmy.jpg
You mean something like this from page 71 :
http://s536.photobucket.com/user/Mitsur ... 8380919795
shelly
shelly
136
Re: 2014 Design
Yes the "snowplough" I had in mind is like this - thank you for finding it, I had not looked well enough.
The other idea ("chimes") is a bit different in that the flat crashstructure has the pillars mounted on in it and forms the continuous section together with a shape like the mp4-22 nose
Holm86
247
Re: 2014 Design
shelly wrote:Yes the "snowplough" I had in mind is like this - thank you for finding it, I had not looked well enough.
Yes i just remembered seeing this. I also think scarbs or someone else made a sketch of a snowplough type 2014 nose. Just cant find that one.
**found it
wuzak
wuzak
467
Re: 2014 Design
**found it
https://pbs.twimg.com/media/BbXZSzGCIAApH3r.jpg:large
Surely that doesn't comply with the regs?
Re: 2014 Design
afaik it was drawn by Scarbs so it think it would be legal.
FW17
169
Re: 2014 Design
wuzak wrote: Surely that doesn't comply with the regs?
I guess you say it does not comply with regard to 3.7.8, but is this new? and does it apply to non structural elements such as turning vanes, vanity panels, snow plows etc.?
Holm86
247
Re: 2014 Design
Thunders wrote:afaik it was drawn by Scarbs so it think it would be legal.
It was Scarbs yes.
